Go to Post However, do not confuse faith in your ability to overcome challenging obstacles, with the difficulty of the obstacles themselves. - Joe G. [more]
Unread 10-02-2010, 11:26
executionR executionR is offline
FRC #3080 (So-called Robotics)
Team Role: Student
executionR is an unknown quantity at this point
Wireless Setup
So here's our problem. We looked up the directions in the manual and followed all the steps correctly. But on the last step, when configuring the LINKSYS router, we have a problem. When trying to change the IP to 10.XX.YY.4. (10.30.80.4 in our case.) In the diagram, they have the IP set to 10.0.0.4 and underneath that, the diagram has changed along with it, but it doesn't change for us.
We decided to start fresh and reset the router and the game controller and re-configure the setup. This is our 2nd year in FIRST and we didn't have this problem last year.
Any ideas?
Unread 10-02-2010, 11:35
ericand's Avatar
ericand ericand is offline
AKA: Eric Anderson
FRC #3765 (Terrabots)
ericand is a jewel in the roughericand is a jewel in the roughericand is a jewel in the rough
Re: Wireless Setup
Are you saying that you can not change the Linksys Router address to
10.<Team>.<Number>.4?
I'm having trouble understanding exactly where you are having problems.
Unread 10-02-2010, 12:39
Re: Wireless Setup
It might not change until you've saved the settings and rebooted the router if you're talking about what I think you might be talking about...
Unread 10-02-2010, 19:32
Team Role: Student
Re: Wireless Setup
I read up another thread and it said that it wouldn't update into it was rebooted again. So I went ahead and just changed it to 10, and when I went to the next step to test it, I was unable to connect to 10.30.80.4 nor 10.30.80.1.
Suggestions?
Unread 10-02-2010, 19:49
Re: Wireless Setup
And you reset your PC's IP address too before trying to reconnect?
Unread 11-02-2010, 07:48
Team Role: Student
Re: Wireless Setup
Yes, I change the static IP and all that good stuff. Can't figure out why it isn't working though.
Gyro setup? team2491 Programming 1 03-02-2010 15:54
Wireless setup Al3+ Programming 7 30-01-2010 14:30
2010 Wireless Setup GunfighterJ Programming 12 16-01-2010 14:16
Wireless Thermometer Wireless Data C222 Technical Discussion 9 11-01-2010 08:01
WI Setup Timelapse Kevin Kolodziej Regional Competitions 2 08-03-2007 10:32
