| View Poll Results: Which OS do you perfer the most? | |||
| Mac |
15 | 22.06% |
| Windows |
36 | 52.94% |
| Linux |
17 | 25.00% |
| Voters: 68. You may not vote on this poll | |||
#16
Re: OS
I always had a preference for Unisys 1100 series Exec 8. Mainly because where I worked, I had the source code and could modify it as needed.
#17
Re: OS
It got to be too much work, cheaper to just throw hardware at it. But, some of it still lives at Apple.
If you think a mac runs fast, try running DOS on a modern computer. That was when elegance wasn't an option - if you couldn't make it run in <640k RAM, it didn't run - and people still had to get things done as fast as possible, but with a 5 MHz clock speed. For certain (non-commercial) programs, I still run DOS, because it's easier to write in and executes very fast on a 100 MHz Pentium. Same calculations in XP take longer. Of course, my daily PC runs XP. Another prisoner of Windows. It could be worse (CP/M for instance) ![]() |
#18
Re: OS
A rational person wouldn't claim that a particular brand automobile is inferior to another if all they've done is test drive both. They wouldn't gain any insight into the reliability, durability, or performance of the car in various conditions. While a first impression is a valid aspect of an educated opinion, it simply isn't sufficient to create one on it's own in the case of operating systems. |
#19
Re: OS
Ok.....
I don't want to spend the money it would cost to acquire a "valid" opinion of the current Mac OS. |
#20
How Fanboys View Other Operating Systems
#21
Re: OS
I grew up on Apple II through Mac OS8 through elementary school. After that, it was Windows all the way.
I made it a whole two weeks of no Windows by using Ubuntu, but that was as long as I could stand it. Just took too much time to research and read how to get everything working like I wanted too. Too many things I can do with a mouse in Windows, that I had to do with a terminal window in Ubuntu. For a server, Linux is great. But for a desktop, I think it'll be quite a long time before I give it another try. Just too many things I do work only on (or better on) Windows. Every now and then when I'm feeling nostalgic, I do enjoy firing up the 8MHz Mac Classic with System 7.5 though. |
#22
Re: OS
It's hard to form an opinion about something after only twenty minutes or less. I bet if you put a seasoned driver of automatic cars into a car with a manual, and told them to drive across town, they'd probably have an unfairly negative opinion of manual transmissions after only twenty minutes due to stalling at every red light and gear shift on hills.
After a day or two of driving gets them over the initial learning curve, their opinion will be much more realistic. Try out Windows 7 (whether it's a friend's computer or one of the computers at Best Buy or similar stores). Download Ububtu (it's free). Try out Mac OS X (at Best Buy or the Apple Store. The Apple Store will let you use the computers there as long as you want). Use all three long enough to get over the intial learning curve, and then you'll have an accurate opinion of what works best for you (it might be more than one OS). Gigabytes are cheap, so dual (triple?) booting is really easy nowadays. Computers are even getting fast enough to run one operating system in a virtual machine inside another operating system without any noticeable lag. I personally dual boot Windows 7 and Mac OS X, use them both daily, and wouldn't give up either. |
#23
Re: OS
Good point about multi boot Art....I have Windows 7 RC and Ubuntu 9.10 on my computer, but I still use XP all the time, and hardly ever use the others. I find them to be kind of lame, and they don't offer anything that I can't do with XP.
I can't put OSX on my machine because Apple doesn't want me as a customer. Says so right in their EULA. |
#24
Re: OS
I voted for Mac, I use linux, and windows 7 is impressive.
#25
Re: OS
I am sorry for any misunderstandings. ![]() |
#26
Re: OS
I wish there was an option for multiple in this poll. I use both windows, and os x in equal amounts. They both have their pros, and their cons which makes it easy to want to switch between the two.
#27
Re: OS
I like Mac OS 10.4.1
until about a month ago, I was running Mac OS 9.2 My internet browser was "Wamcom" which was a custom build of Mozilla 2 or something like that...I had ZERO javascript support, and it was slow as a snail...Not to mention it only had a 6GB hard drive. Now I have Safari 4 with my OS 10.4 I am still running it on my G4 quicksilver, so not much about the speed has changed. But overall It works much better, and I upgraded to 120GB of space! The only downside is: I still only have 512 MB of ram ![]() Last edited by Kage : 03-01-2010 at 16:43. |
#28
Re: OS
I dual-boot XP and Ubuntu... Ubuntu works well for general stuff, and I use XP for CAD and gaming.
#29
Re: OS
Dude! use Ubuntu! it works with netbeans programming OOTB! anything you need is just an apt-get away!
#30
Re: OS
i <3 windows vista basic.
