Go to Post Am I the only one who thinks robots are the main attraction of a regional, and there isn't a need for more distraction? - Adam Richards [more]
Unread 06-02-2010, 17:38
ygd ygd is offline
FRC #3341 (Manhattan Project)
ygd is an unknown quantity at this point
Question Dashboard not working
I'm using Java, my code for the Dashboard looks like this:
Dashboard lowDashData = DriverStation.getInstance().getDashboardPackerLow();
        lowDashData.addCluster(); {
                lowDashData.addDouble(j1.getX());
                lowDashData.addDouble(j1.getY());
            } lowDashData.finalizeCluster();
                lowDashData.addDouble(j2.getX());
                lowDashData.addDouble(j2.getY());
        lowDashData.commit();
        System.out.println("Dashboard updated");
Where j1 is the left joystick and j2 is the right joystick.
When I run my code, this shows up on the classmate:
Warning: The Dasboard Datatype used thy the robot project and this dashboard do not match. See Diagram for more details.
What's going on here and how can I fix it?
Unread 06-02-2010, 22:30
Michael Schloz Michael Schloz is offline
FRC #1523 (M.A.R.S. Robotics)
Michael Schloz is an unknown quantity at this point
Re: Dashboard not working
You need to make sure you are packing your clusters up in the correct order to the dashboard. If you are using the one that FIRST provided, go in to labview and check it out to make sure you are packing every thing correctly.
Unread 10-02-2010, 20:06
ygd ygd is offline
How do I do that? I have no idea how to use LabView.
Unread 11-02-2010, 07:16
joshholat joshholat is offline
FRC #0930
joshholat is an unknown quantity at this point
You have to make a new LabView Dashboard project that takes the same amount of inputs into LabView that you are outputting from Java. Use LabView 8.6 on the disc that you got from the FRC KOP. The Dashboard project comes standard. Then you basically remove the inputs from the default project that you don't need and add your own (graphs, LEDs, etc).
Also, we did get that error commonly, too. If you've already made a new Dashboard project, that error is usually from the camera because I don't believe you can use the camera during competition. At least not for sending video to the Dashboard, but it is available for tracking.
Camera working in C++ and default dashboard pafwl C/C++ 0 03-02-2010 22:06
Deploying not working bobwrit NI LabVIEW 1 16-02-2009 22:09
NI Dashboard only partially working? Tim Skloss Programming 4 05-01-2009 10:37
p2 not working? Lone_Wolf92c Programming 5 22-02-2008 08:49
IR Board Not Working (But NOT Fried) itsme Electrical 2 18-02-2008 06:11
