Go to Post If you base a team on how well you do on the field you have a much harder time winning. - Bob Steele [more]
Unread 10-02-2010, 08:50
rytcd rytcd is offline
FRC #3140
rytcd is an unknown quantity at this point
4 vs 6 wheels
are there any real advantages to having an extra 2 wheels? pros and cons? we dont see much of a difference in descriptions of their performances. (we are a rookie team)
Unread 10-02-2010, 08:56
O'Sancheski O'Sancheski is offline
O'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond repute
Re: 4 vs 6 wheels
team paragon is doing a six wheel drive robot... the two middle wheels are high traction IFI wheels... and our four outside wheels are the 6" AndyMarks that came in the KOP... each side drive is powered by our custom two speed pneumatic shifters... putting the power with two chains to drive the three wheels on each side.
Unread 10-02-2010, 09:07
lbarger's Avatar
lbarger lbarger is offline
Senior LRI NC District
AKA: Lee Barger
FRC #0587 (The Hedgehogs)
lbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud of
Re: 4 vs 6 wheels
Four wheel drive, skid steer, robots take a lot of power to turn, especially if it uses high traction wheels. The advantage of 6 wheels is that the corner wheels bare less of the weight, making it easier to turn. Most 6 wheel configurations use either lower friction wheels on the corner or the center wheels are slightly lower than the corner wheels (1/16 - 1/8") to carry a larger portion of the weight. The 'wobble' from the lower wheel is almost unnoticed on carpet.
The disadvantage of 6 wheel robots this year is they must match the 45 degree incline of the bump to go over it (if you choose to do so). A long wheel base 4 wheel robot can cross the bump with less total tilt. You do have to watch you total ground clearance as you can high center if it the frame is too low.
Unread 10-02-2010, 09:08
hipsterjr's Avatar
hipsterjr hipsterjr is offline
Your bot can score but can it dance
AKA: CJ
FRC #4451 (The Burning Magnetos)
hipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond repute
Send a message via AIM to hipsterjr
Re: 4 vs 6 wheels
We think it adds some much of an advantage that we doubled it and going with an 8 wheel design! Unless compensated for, rigid 6 wheel designs tend to slam down when coming over the crest of the bump. We tested two of our past 6 wheel robots that were VERY solid, and wound up breaking a axle on one of them coming down the back side.
2010 Palmetto Chairmens Winner
2009 Peachtree Finalist Thanks 1319 & 590 "Sure your robot can score, but can it dance?!"
2008 Palmetto Regional Finalist Thanks 343 & 804
2008 Florida Regional Finalist Thanks 179 & 69
2007 Palmetto Regional winners Thanks 1319 & 832
2005 Palmetto Chairmens Winner
Unread 10-02-2010, 12:39
Wayne TenBrink's Avatar
Wayne TenBrink Wayne TenBrink is offline
<< (2008 Game Piece)
FRC #1918 (NC Gears)
Wayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond repute
Re: 4 vs 6 wheels
Aother option for 6WD (or 8) is to elevate all center wheels so that they only come into play when crossing the bump. By having them elevated, you don't get the traction benefit on flat ground, but you can eliminate the "high centering" while still reducing the angle that the chassis must reach while crossing the bump - you go over smoother and are less likely to tip because you don't rock forward so much when coming off the top of the bump.
NC Gears (Newaygo County Geeks Engineering Awesome Robotic Solutions)
FRC 1918 (Competing at St. Joseph and West MI in 2017)
FTC 6043 & 7911
Unread 10-02-2010, 13:58
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
Re: 4 vs 6 wheels
well, it's harder to strafe with 6 wheels, and you will have a harder time getting over the bump W/O crashing while you go over it, and you can't strafe on the bump with 6 wheels.
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 10-02-2010, 14:36
Chris is me's Avatar
AKA: Pinecone
Re: 4 vs 6 wheels
All of this assumes a long robot. A wide robot can get away with 4wd high traction wheels with the ability to turn without having to use omni wheels.
Normal Year: Four wheel drive robots with high traction wheels on all four spots have massive problems turning correctly. Adding a 5th and 6th wheel in the center helps with this a little bit. On top of that, "dropping" the center wheels 1/8" so that at any one time, only four wheels are touching the ground will make turning even easier, since the robot's wheel base will be wider than it is long. This allows robots to turn easily while still maintaining a 100% high traction drive for pushing and dealing with defense, while a four wheel drive would need some lower traction or omni wheels, which makes them vulnerable to defense on one side of their drivetrain.
This year: The debate over four versus more than four wheels is more complex. As the Kitbot is built now, a four wheel drive with big wheels is more able to deal with the bump than a 6+ wheel drive, since half of the robot "falls down" before the other half when 6+ wheel systems have all of the robot "faling down" at once. Barring an unconventional design, you've reached a design tradeoff. If you can't make a cool suspension or something, do you want better, more safe bump climbing ability at the expense of half of your drive having less traction? Or do you want a full, high traction drive that has to deal with more forces when it comes to bump traversing?
This is pushing all active suspensions, etc. aside. This particular tradeoff is one that bothered me for the first whole week of build season, and I hope the decisions made were the best.
Unread 10-02-2010, 15:25
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Re: 4 vs 6 wheels
This is an interesting post. We are weighing to what degree the focus needs to be on one or the other.
How much time will be spent going over a bump, if any?
In the game a soccer, defense is a huge part of the game.
Will teams spend the majority of the time in contact with opposing robots?
If so, will traction be important?
For us, an 8wd addresses all of the concerns.
Unread 10-02-2010, 21:24
I.U.man_22 I.U.man_22 is offline
AKA: phillip
FRC #2360 (POWER Storm 2360)
I.U.man_22 will become famous soon enough
Send a message via AIM to I.U.man_22
Re: 4 vs 6 wheels
At the beginning of our season we set out to have a six wheel drive. We built it and tested it. We found that the center wheels on the six wheel drives actually pushed us back over causing us to flip over and never actually go over the bump. We assembled the kit bot chassis with four wheels and it went right over the bump with out any problems.
On the both drives we used the andymark traction wheels.
2360 POWER Storm Robotics
Phillip Welsh
Unread 10-02-2010, 21:29
AKA: Pinecone
Re: 4 vs 6 wheels
Were all 6 wheels powered? Where was your center of gravity located roughly?
Unread 10-02-2010, 22:40
andy174drive's Avatar
andy174drive andy174drive is offline
FRC Team 0174
AKA: Andy Dodd
FRC #0174 (Arctic Warriors)
Team Role: Driver
andy174drive is an unknown quantity at this point
Send a message via AIM to andy174drive
Re: 4 vs 6 wheels
An 8 wheeled robot is pretty sweet and if you work it right really effective. Not speaking from experience or anything. I've seen a few videos of teams with both four and six wheel drive systems that look kinda scary going over the bump. So far our wheels actually work with the bump for a smooth ride. I personally don't wanna shake the robot to pieces flying over the bumps.
Unread 10-02-2010, 23:11
ChrisP's Avatar
ChrisP ChrisP is offline
AKA: lil'C
ChrisP will become famous soon enoughChrisP will become famous soon enough
Re: 4 vs 6 wheels
Generally speaking, 4wd goes over the bump easier, but has more problems turning in place, while 6wd has more trouble going over the bump, but turns fairly well.
Maybe you could find a compromise between the two?
Big C here to help!
Unread 10-02-2010, 23:16
fuzzy1718 fuzzy1718 is offline
MTU class of '15
fuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant future
Re: 4 vs 6 wheels
most teams typically use a 6wd system, assuming the long configuration. If it is the wide configuration 4 wheels are all that is needed. A word of caution though, my team assembled the kit bot in the wide configuration (4wd) unless you mount your battery 1/2 way below the frame dead center you will flip on the bump. As far as long configuration goes there are some tradeoffs:
4wd:
-high CG due to the need for clearence. High CG = more likely to tip
-Less room for kicker close to ground
-Less traction = less pushing power
6+wd:
+Low CG
+More space for kicker close to ground
+More pussing power. Due to the increased traction caused by more high traction wheels
-cant strattle the bump
-more strain on drivtrain do to "crash down" when crossing the bump
I am a little biased because of what my team has kicked around. Anyone else have any pros or cons to add?
What FIRST has taught me:
Money is not everything.
In order to change a culture one must change the hearts of the next generation.
The fish rots from the head down.
Why we do something is often more important than what we do.
Repeated success is often sown on the backs of a few, but reaped by many.
Unread 11-02-2010, 19:10
machetemonkey machetemonkey is offline
AKA: Nate
FRC #2491 (No Mythic)
machetemonkey is an unknown quantity at this point
Re: 4 vs 6 wheels
our robot uses 4 large (like, very large) wheels with not tons of traction (I'd say a bit less than the KoP grippy wheels), and we use the long-wheelbase configuration. We've had trouble getting the robot to turn at all, however most of this is, we believe, due to our loose chain tensioners which defeated their purpose by skipping whenever the drivetrain was under stress. haha.
Anyways, my point is to not underestimate any given issue you might have. You could say "meh, it may not work well but at least it'll work" when designing and find out it doesn't work at all.
"No Mythical Creatures in My Classroom!"
-Myself
Yes, my dislike of twilight sparked the inside joke that created our team name. I feel special.
Unread 11-02-2010, 20:38
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Re: 4 vs 6 wheels
I think that both 4 and 6 wheel drive is not as good as tanks treads (what we are using), since with treads, you get enormous amounts of traction, plus easy turning, AND lots of surface area when de-bumping.
6 wheels with only 2 powered wheels bhsrobotics1671 General Forum 15 14-01-2008 17:28
Friction coefficients for Omni wheels and Mecanum wheels from AndyMark Andy Baker Technical Discussion 11 16-12-2006 19:40
TO much traction??? (ifi wheels or AM wheels) Heretic121 Technical Discussion 9 04-02-2006 12:09
Image Discuss: Wheels- you want wheels - more from team 25 CD47-Bot Extra Discussion 10 07-09-2003 20:33
Wonder Wheels (aka Side Slip Wheels) Scott358 Technical Discussion 4 08-01-2002 12:36
