Go to Post Two students with no clue but enough dedication to work on something is always better than one expert who doesn't care enough not to leaveit until the last day. - Matt Krass [more]
Unread 10-02-2010, 21:32
yoshibrock's Avatar
yoshibrock yoshibrock is offline
Mechanical Magician
AKA: Brock
FRC #0540 (Talon)
yoshibrock will become famous soon enoughyoshibrock will become famous soon enough
Send a message via AIM to yoshibrock
Is this legal (Bumpers)?
Is this legal? Sorry about the quality by the way, I draw faster by hand then in paint
http://picasaweb.google.com/lh/photo/STRXhahvXQF64xMHxX2wBg?authkey=Gv1sRgCOC8s6vpmcqtK g&feat=directlink
The bumper goes inside the c-brackets, which are mounted on a piece of the kit frame. This is what's currently on our robot, and it takes a bit of work to get big c-channel, so we'd like it to stay if possible.
However, I'm worried that it wouldn't be considered "Robust" by the inspection officers, but I'm not sure. What do you think?
There is no charge for awesomeness.
Am I a hero? I really can't say, but yes.
Unread 10-02-2010, 21:47
yoshibrock's Avatar
Mechanical Magician
AKA: Brock
FRC #0540 (Talon)
Re: Is this legal (Bumpers)?
I'm not completely sure, but I think the bumpers will slide into the c-brackets and be pinned/bolted in place. What worries me more is whether or not the "kitbot" chassis bar is wide enough (up and down) to be considered robust. It feels robust, but even I admit that it looks kinda wimpy
And I'd like to show a picture, but it's kinda secretive....plus I don't have a picture.
Unread 10-02-2010, 21:52
nitneylion452's Avatar
AKA: Joe Lee
I don't think so, namely because the c brackets may be called part of the frame, or because the connection will not be robust. Here's a suggestion that has no gray area (It's what we're using on our robot):
http://www.mcmaster.com/#threaded-inserts/=5rizbc
Hope that helps.
(Ignore what I said before)
Unread 10-02-2010, 22:08
yoshibrock's Avatar
Mechanical Magician
AKA: Brock
FRC #0540 (Talon)
What exactly are the inserts to be used for? The c-bracket part of the frame is liable to change to fit rules. It's the other part, the part the c-brackets are mounted on that worries me. Thanks for the suggestion though.
Unread 10-02-2010, 22:29
AKA: Joe Lee
You would put the inserts into the plywood and put a bolt in through the opposite side. This gives you the ability to remove the bumpers simply by removing a few bolts.
Unread 10-02-2010, 22:32
yoshibrock's Avatar
Mechanical Magician
AKA: Brock
FRC #0540 (Talon)
Oh! That is a good idea, thanks. But what do you think about using the kit-bot frame as a holder for the bumpers? Is it strong enough?
Unread 11-02-2010, 17:59
daltore's Avatar
daltore daltore is offline
Electronics/programming/design
AKA: Aaron Osmer
FRC #3529 (ausTIN CANs)
daltore has a spectacular aura aboutdaltore has a spectacular aura aboutdaltore has a spectacular aura about
Send a message via AIM to daltore Send a message via MSN to daltore Send a message via Yahoo to daltore
Something like this? This is the one our team is using, and it's working spectacularly well.
Unread 11-02-2010, 18:23
Hito Seika's Avatar
Hito Seika Hito Seika is offline
aka Garrett
FRC #1225 (Amperage Roboticcs)
Hito Seika is infamous around these partsHito Seika is infamous around these partsHito Seika is infamous around these partsHito Seika is infamous around these parts
Hay when you attach your bumpers to the robot, do you have to use the bolts like in Figure 8-1 in the rule book?
Sorry about my spelling ….I’m a horrible speller
Unread 11-02-2010, 18:33
The specific wording is found in <R07-I>:
I. BUMPERS must attach to the FRAME PERIMETER of the ROBOT with a rigid fastening system to form a tight, robust connection to the main structure/frame (e.g. not attached with Velcro). The attachment system must be designed to withstand vigorous game play – nut and bolt fasteners are recommended. All removable fasteners (e.g. bolts, locking pins, pip-pins, etc.) will be considered part of the BUMPERS.
Unread 11-02-2010, 19:12
It is hard for me to make a decision on the drawing alone. The first thing I would question is whether this design allows for the 1" limit for hard parts in the bumper here...
N. “Hard” parts of the BUMPER (i.e. plywood backing, fastening system, and clamping angles) may extend up to a maximum of one inch beyond the FRAME PERIMETER. “Soft” parts of the BUMPERS (i.e. pool noodles and cloth covering) may extend up to 3½ inches beyond the FRAME PERIMETER.
The second would be the method of attachment as it applies here...
The third would be to check that the support structure is in fact entirely within the bumper zone.
And finally a quick check of the various Team Updates and Q&A responses pertaining to sizing, FRAME PERIMETER, and frame structure.
I am not sure that your design would pass the test on all of these.
Unread 11-02-2010, 22:06
yoshibrock's Avatar
Mechanical Magician
AKA: Brock
FRC #0540 (Talon)
Thanks for all the help everyone! Out of concern for the legality of our bumper system, we've decided to update our "bumper frame" per se to full sized c-channel. We'll ensure we follow all the other rules as well. Thanks for the help, and good luck in these last couple of weeks!
Unread 12-02-2010, 07:33
Brock,
The C channel in the drawing link above is an issue with attachment and hard parts. A full length channel still has me concerned. Please read the bumper rule section completely.
Unread 12-02-2010, 09:45
yoshibrock's Avatar
Mechanical Magician
AKA: Brock
FRC #0540 (Talon)
Thanks. I'll read the bumper rules carefully to make sure we don't violate the hard parts and attachment rules. I feel like this awful picture isn't exactly communication the idea correctly, so we'll see. We'll post the full robot next week, so there will be actual pictures.
Unread 12-02-2010, 11:58
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
We were planning on doing something similar with our bumpers, and having seen this we're carefully considering the rules again, which led to a few questions from our handy local inspector First, a picture of our idea, as accurate as we can be with pictures is attached, showing both a side view and a top view. now, a description:
We use C channel that is slightly larger than the kit-bot frame on the bumpers. It's attached to the bumpers securely (most likely with two bolts/tee nuts per section of C channel). When we attach it to the robot, the C channel fits snugly around the frame, with holes for bolts to drop through vertically to secure it. Due to the snug fit and the bolts holding it in place, the bumpers are securely mounted, with no wiggle room - i believe this would meet <R07> I.
The C channel would be Aluminum, less than 1/4 inch thick. Since this is snug against the frame (with holes drilled out of the frame to allow incursion of the bolt heads holding the C channel to the bumpers), the total depth of hard materials would be less than 1 inch (3/4 of plywood and, for example, 1/8 of aluminum). This would meet <R07> N.
However, we aren't sure about <R07> M - specifically the statement that the bumper has to be supported along its full length. Our robot design would make it difficult to have C channel along the full length of the bumpers - most likely we would have 2-3 sections maybe 3-5 inches long. Would the resultant 1/8 inch gap between the plywood and the frame, in sections where there's no additional C channel, be permitted? A simple solution to this, of course, is to build out the frame in those "unsupported" sections an additional 1/8 inch, which would provide a flush mount for the bumper (pictured in the attached image as red). Our feeling is that 1/8 inch is well with in the designed flexibility for plywood of this type, and such a gap would pose no structural hazard to the frame or bumpers. In fact, you might end up with a gap that big from simple warping of the plywood.
We ask this with the full understanding that you aren't the GDC, and if asked to the GDC we would get the canned "we cannot comment on specific designs..." response Since at least one other team is considering this, we figured posting our concerns and possible work around to remain within the rules could help the community.
Unread 12-02-2010, 12:39
Eagle (what is your name again?)
The rule you reference refers to robot structure that backs up the bumper. i.e. the part of the frame not shown in your drawing. The design criteria include the backing, knowing full well a 150 LB robot at any speed would be able to break or severely weaken the 3/4" plywood. ( I think Dave Lavery showed a picture of a of the damage from a robot hitting the wall last year.) With robot structural members behind the bumper plywood, the whole system provides what the GDC expects would protect the robot during most legal game play. Using the C channel in your drawing for attaching the bumper is a good way to attach the bumper, but the structure is still part of the rule. In your example, the 1/8" gap caused by the C channel would not compromise the 3/4" plywood as it is compressed against the frame.
In this year's game, contact with other robots on the bump will cause some interaction to occur at angles not encountered during games on a flat field. That being said, bumpers mounted only in the middle with no backing robot frame structure will suffer from these non-parallel contacts. Bumper/robot damage would be the result.
pic: Second year team needs your help: Are these bumpers legal?!?!!? Tyler Olds Extra Discussion 28 10-02-2010 23:47
Touchsensors in the Bumpers legal? Kevka Electrical 8 25-01-2010 14:25
Is this legal? indubitably Rules/Strategy 9 10-01-2010 03:20
2 sets of bumpers legal? ChuckDickerson General Forum 33 07-03-2009 12:37
is this legal? natalie604 Pneumatics 5 31-01-2008 10:03
