Go to Post when all else fails, try making the bot go slower - KenWittlief [more]
Unread 09-02-2010, 17:41
Damaku250's Avatar
Damaku250 Damaku250 is offline
Electromechaneumatics guy
AKA: Craig Hoo
FRC #3161 (H.T. Tronic Titans)
Team Role: Electrical
Damaku250 is an unknown quantity at this point
Re: Andymark Planetary Transmission...
Which gearbox are you refereing to? If you are talking about the AM Planetary Gearbox (http://www.andymark.biz/am-0002.html),then yes you have to remove the existing gear and press the new gear that comes with the planetary on to the shaft of the motor.
Yeah, that's the one, but to my knowledge it did not come with a new gear.
:S As we are a rookie team we weren't aware of this.
I do not believe our school has an arbor press either.
Is it a viable option to drill out the mounting pate to a diameter that would accept the gear?
-Rookie All Star Award [WAT Regional 2010]
Electrical/Control systems, Mechanical and Pneumatics teams, Human player
Unread 09-02-2010, 17:48
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Originally Posted by Damaku250 View Post
Could anyone tell me how to mount a FP motor to the this kind of gearbox? I'm not sure if we're allowed to yank the gear off, and if so, how?
Getting the pinion off a FP is actually pretty simple if you're willing to stoop to the level of pure brute force.
The trick is that the pinion material is actually relatively soft and deformable. So what you want to do is squish the pinion by grabbing it in a vise, arbor press, etc. You just squish the pinion from one direction, then turn it 90 degrees and squish it from the other. This deforms the hole in the pinion enough to make it MUCH easier to remove. You can tell if you're doing it right by looking at the shaft-pinion interface. If you're deforming the pinion, you'll see a small gap develop there.
Note, you must be extremely careful that you're only crushing the pinion and not some part of your motor's frame. Also, this isn't the nicest way in the world to use a vise, so try to pick one that you don't care as much about. Finally, this technique works much better with the 15-tooth pinion than the 19-tooth.
Unread 09-02-2010, 17:58
David Guzman's Avatar
David Guzman David Guzman is offline
AKA: Dave
FRC #1251 (The Techtigers)
David Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant future
The problem is not to make the gear fit through the hole, the planetary is designed to work with the 15 tooth 32 pitch pinion and it will not work with anything else (others would not mesh properly with the planet gears).It should have come with the Planetaries, if it didn't I would try to contact AndyMark and ask them about it. The website lists it as part of the hardware.
http://store.andymark.biz/am-0002.html
Hardware
# Two 8mm id ball bearings, (19mm od, 22mm od) supporting output shaft
# steel planet and sun gears, 32 dp, 20 degree p.a.
# Five planet gears (12 tooth)
# 15 tooth sun gear, with 0.125 inch bore
# 40 tooth ring gear
# Two #10-32 mounting holes, on a 1 inch radius from center
If you do not have an Arbor Press, your best bet is to order the mounting plates w/ motor that are ready to be installed. Our team has gotten away with using a vice to press the gear onto the shaft at the events but I do not recommend it.
Team 1251 The Techtigers
2010 FL Regional Winner (BIG thanks to 86 and 1612)
2009 FL Regional Finalist (BIG thanks to 79 and 744)
2008 FL Regional Winner, FL GM Industrial Design, SC GM Industrial Design
2007 FL Regional Winner, FL GM Industrial Design, Palmetto Regional Finalist, Palmetto Motorola Quality.
2006 Palmetto Regional Winner, Daimler Chrysler Team Spirit Award
2005 FL Regional Judges Award, FL Regional 3rd seeded and finalist, Palmetto Regional Xerox Creativity Award, Palmetto Regional 1st seeded and finalist
2004 UCF Regional Rookie All-star Award
Unread 09-02-2010, 18:47
Damaku250's Avatar
AKA: Craig Hoo
Would it be in any way acceptable to bore the planetary mounting cap larger?
We believe this would be the easiest way as it would allow for easy motor replacement in the event of failure, and would be the most economical.
Unread 09-02-2010, 18:57
Borisdamole Borisdamole is offline
mercernary machinist
AKA: Taylor
FRC #0973 (most with 973)
Borisdamole is just really niceBorisdamole is just really niceBorisdamole is just really niceBorisdamole is just really niceBorisdamole is just really nice
Send a message via AIM to Borisdamole
bane bots trans. have cost us too many matches for me to EVER trust them again...
ANDY MARK is the way to go....
AM parts are all high quality, easy to use, and the stand behind their product 100%
wish I could say that about bane bots...... I cant....
OUTWORK US
Unread 09-02-2010, 22:18
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
I would not recommend making any holes in the gearbox or motor mounting plate. This will allow debris to enter the gearbox and do bad things to it.
Unread 09-02-2010, 22:39
Damaku250's Avatar
AKA: Craig Hoo
According to one of our mentors/post-secondary students, there was a shipping error resulting in some teams actually ending up with a 15-tooth pinion on the FP motor, which I think might be the case as it seems to mesh properly with the AM planetary. the normal stock 19-tooth wouldn't do that would it?
If this is the case, would that mean we just need to yank the gear off (with a neighbouring team's arbor press), install the back plate then re-install it?
Unread 09-02-2010, 22:50
Chris is me's Avatar
AKA: Pinecone
The Planetary comes with the proper gear to install on the FP output shaft. Just to be safe, I would always use that.
Unread 09-02-2010, 23:12
Damaku250's Avatar
AKA: Craig Hoo
As stated above, we appear not to have received said gear.
Unread 10-02-2010, 00:57
Steven Sigley's Avatar
Steven Sigley Steven Sigley is offline
Electrical Mentor for Team 701
FRC #0701 (RoboVikes)
Steven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to all
We're using the planetaries in a funky way, 2 FP's, going into 2 planetaries going into a toughbox. This will operate our kicker.
2013 Colorado Regional Champions!
2013 Sacramento Regional Champions!
Unread 10-02-2010, 18:23
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
wow, got enough torque there dude?
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 10-02-2010, 22:52
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Originally Posted by qwertyuiop[]\ View Post
Banebots planetary is definetly super reliable. my team has reused the same 4 gearboxes for drivetrain on our robot for 3 years running. not once have we experienced any problem. People just have a bias against banebots because of a bad gearbox along time ago(maybe not that long). But people who think banebots have zero quality really are just close minded to the new gearboxes that they have made.
Steve, were you around during the whole plate-bending-in-half experience that went on with the banebots transmissions (I believe it was in '07)?
In a competition like FIRST where you pay thousands of dollars to enter, and then have 12 matches total during a regional, a single component failure is a major major thing for most teams.
A large number of the banebots transmissions failed, some catastrophically. I can't imagine the cost of that if your translated that into lost design, engineering and playing time for all those many many teams that used the gearboxes in the KOP.
On top of that, Banebots compounded the issue with very poor customer service.
Banebots may be a very good company now, but once you've been severely burned by a company's components, there are very few people who would go back and try them again just to see if they've improved.
http://www.chiefdelphi.com/forums/sh...=banebots+fail
I harbor no ill will towards banebots.... but will be a long long time before I ever consider another one of their products.
Unread 10-02-2010, 22:53
ChrisP's Avatar
ChrisP ChrisP is offline
AKA: lil'C
ChrisP will become famous soon enoughChrisP will become famous soon enough
This year our team has decided to go with the andy mark transmissions yet again, and they're doing great!
Big C here to help!
Unread 10-02-2010, 22:54
Tom Line's Avatar
That isn't a funky way. If you look at the torque curves and free speeds, a fisherprice through an AM planetary gearbox ends up being nearly the equivalent of a CIM. Just don't try to run it slowly. Fishes don't like going slowly.
Unread 10-02-2010, 23:09
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Sound like you harbor a lot of ill will towards them and I remember them busting their buts and spending a fortune in customer service when that first problem happened.
I haven't used their products since that initial problem but then again I live 40 miles from AndyMark and I love their products.
Nobody is perfect, not everyone gets it right the first time. Ask somebody about the problems with the first AM planetary boxes, broken omni wheels and those first 6" mech wheels. But they learned from their mistakes and these products have evolved into superior products.
I get a bit frustrated when companies that have worked hard to make our jobs easier and have spent their hard earned money to support us continue to be bashed years after problems occurred. I still cringe when people bash Festo for the valve problems from a few years back even when I know that many of these problems were because of improper use. Lucky they still continue to donate these products.
Sorry about the tenor of this post but these thoughts have been brewing in me for a while.
12 to 1 Bane Bots Planetary Transmission 5n1p3r Motors 5 26-01-2009 21:47
AndyMark CIM Planetary Gearbox Torque Specs Needed KTorak Technical Discussion 4 17-01-2008 18:53
Binding AndyMark Toughbox transmission? David Fort Motors 16 16-01-2008 20:08
Second AndyMark transmission query N0s3Nugg3t Technical Discussion 2 05-01-2008 15:29
Andymark Planetary Alex.Norton Technical Discussion 3 06-07-2007 11:12
