Go to Post Point is, there is no definite answer. This is FIRST, Whatever works well with your team is the best. - NelsonMichael [more]
Unread 10-02-2010, 12:01
jeser#1772's Avatar
jeser#1772 jeser#1772 is offline
1772 and 4613
FRC #4613 (The Brazilian Trail Blazers and Barker RedBacks)
jeser#1772 has a reputation beyond reputejeser#1772 has a reputation beyond reputejeser#1772 has a reputation beyond reputejeser#1772 has a reputation beyond reputejeser#1772 has a reputation beyond reputejeser#1772 has a reputation beyond reputejeser#1772 has a reputation beyond reputejeser#1772 has a reputation beyond reputejeser#1772 has a reputation beyond reputejeser#1772 has a reputation beyond reputejeser#1772 has a reputation beyond repute
Send a message via MSN to jeser#1772
pic: #1772 robot
Josh Drake's Avatar
Josh Drake Josh Drake is offline
Engineering Mentor
FRC #5403 (Aluminosity)
Josh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond repute
Re: pic: #1772 robot
Very nice looking package. Good luck this year!
07'-10' FRC 343
11'-12' FRC 2751
13'-14' FRC 3494
15'-16' FRC 5403
Unread 10-02-2010, 15:45
Jimmy Cao Jimmy Cao is offline
AKA: Jimmy Cao
Jimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant future
That's some nice machining! =O I especially like the labeling of the Bumper Zone.
Just one little thing. It looks like your drive shafts stick past the frame? I think that was ruled to be in violation of the frame perimeter rules (even if it falls within the 28x38 rules).
Jimmy Cao
Team 469 2006-2010 Student/Alumni
Team 830 2011-2012 Mentor
Unread 10-02-2010, 23:29
nnfuller's Avatar
nnfuller nnfuller is offline
AKA: Alumni
FRC #2733 (Pigmice)
nnfuller is on a distinguished road
I believe those would be considered "minor extrusions"
Unread 10-02-2010, 23:32
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Yes, but there is no rule that allows minor protrusions to stick out of a vertical projection of the FRAME PERIMETER if they are not inside the BUMPER ZONE.
The frame as pictured, appears like it may have a problem with <R16>
Unread 10-02-2010, 23:34
_Tanto_'s Avatar
_Tanto_ _Tanto_ is offline
_Tanto_ is an unknown quantity at this point
Very nice! ... are you guys capable of going under the bump or are you a little too tall?
"a triscuit can only do what a triscuit does"
ChrisP's Avatar
ChrisP ChrisP is offline
AKA: lil'C
ChrisP will become famous soon enoughChrisP will become famous soon enough
I like your 6 wheel drive design, and the compact size of your robot suggests that you will be going under the bump, a good plan indeed. All in all, good job!
Big C here to help!
Unread 11-02-2010, 08:02
jeser#1772's Avatar
1772 and 4613
hello
thanks the replies guys!
the bumper zone has 1/2 inch more than the rest
and the max perimeter is 16' x 23' x 31
1772 - The Brazilian Trail Blazers
4613 - Barker RedBacks
Unread 11-02-2010, 08:24
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Water-jet FTW?
Unread 11-02-2010, 08:29
jeser#1772's Avatar
1772 and 4613
laser cut...
Unread 11-02-2010, 09:59
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Well it was one of the two
Unread 11-02-2010, 12:45
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Originally Posted by jeser#1772 View Post
hello
Very nice! That's one good looking machine right there.
pic: Summer Robot- The robot mattd7591 Extra Discussion 2 10-09-2008 08:39
pic: 233 robot teaser, yep, theres our robot ; ) ducttapedude Extra Discussion 20 15-02-2007 22:02
Brazilian Team #1772 Needs Victors misiuk Electrical 2 24-01-2006 14:20
pic: Team 114 Real Robot Vs. Inventor Robot James114 Robot Showcase 3 18-02-2005 13:02
pic: Closeup of the robot hanging on robot CD47-Bot Extra Discussion 16 09-03-2004 18:27
