Re: <R07>E Bumper clarification
I think the key word is "EXPOSED". The bumper backing facing the robot isn't exposed.
I would ask this question in Q&A, but unfortunately I do not have access to. |
That's what I get for poor organization of my manual folder.*Deletes RevA* Oh, well, I would have asked the question anyway. Brian, As noted above, I have asked this on the Q&A. |
Yeah, why would they specify the exposed bumper material if they meant all of it? I can't see how the word "exposed" means "all of the plywood". The figure supports my conclusion. Bump on!
My definition of exposed would be if the plywood is visible when the bumpers are installed on the robot. Our current bumpers have quite a but of exposed plywood on the side facing our robot. They are supported in the back by a piece of 1" tall plywood attached to a piece of 1x1 aluminum box. The brackets holding the bumpers in place are fairly small and the fabric currently only wraps around about 1-1.5" around each edge leaving between .5" and 1" of backing I would consider exposed on either side of the supporting frame member. I agree with your conclusion, but am not fond of taking risks when it comes to inspection. Safer to ask the question and find out the answer now. |
I don't think the part of the bumper that is against the robot frame is "exposed", but I'm neither the GDC nor a robot inspector. |
#7
I really believe they mean that the back of the BUMPER needs to be covered with fabric. If you look at the rule and shift your eyes over to "enclose the BUMPER backing (plywood)" I think this very clearly stated that the back of the BUMPER(part attached to the FRAME) must be covered.
This is how our team views is, this is how we made it. If you look at it from a safety point of view; having the back covered helps prevent splinters when dealing with the BUMPER. |
#8
That said, any team that opts to cover the back will not be declared illegal. |
#9
Steve, don't try to fail a team who doesn't have the backside of their bumpers covered. http://forums.usfirst.org/showthread.php?t=14610
After reading the update number three I will say that the GDC means that anything that can be seen from the audience should be covered. I take this to mean that the backing now does not need to be covered.
Note to self: stop building and read updates faster. |
| Clarification on bumper rule... | RoboSparks | Rules/Strategy | 2 | 16-01-2010 07:29 |
| <R07> F -source for bumper fabric? | Andy Brockway | Rules/Strategy | 9 | 12-01-2010 07:36 |
| pic: R07-Bumper configuration legality | Trevor_Decker | Extra Discussion | 5 | 11-01-2010 12:20 |
| R07-Bumper configuration legality | Trevor_Decker | Rules/Strategy | 2 | 10-01-2010 18:38 |
| Your opinion: does our mesh violate rule R07?? | RoboMaster | Rules/Strategy | 9 | 16-02-2009 18:46 |
