Go to Post "Insanity: doing the same thing over and over again and expecting different results." - Albert Einstein - Edward Debler [more]
Unread 11-02-2010, 02:41
Re: 2010 FRC camera vision tracking delay, image processing lag
You may already have what you need, but I was pretty sure the sample code for C++ and Java sent the data to the dashboard.
Greg McKaskle
Unread 11-02-2010, 10:21
pspeer's Avatar
pspeer pspeer is offline
Programming / Electronics
FRC #1730 (TeamDriven)
pspeer is an unknown quantity at this point
Our team is working with C++ using the WindRiver workbench (not labview) and data is already correctly sent back to the driverstation (data packing is not an issue).
Specifically our issue is the amout of time the tracking function takes to execute, we want it placed in it's own thread.
We need C++ help with:
(1) Creating a new VxWorks task
(to separate vision processing into its own task)
(2) Creating a shared global variable using semaphores
(to pass "target array" information back to the main OperatorControl loop)
Sorry for the confusion, I will post sample code later tonight to illustrate this concept.
Unread 11-02-2010, 11:52
slavik262's Avatar
slavik262 slavik262 is offline
We do what we must because we can.
AKA: Matt Kline
FRC #0537 (Charger Robotics)
slavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to behold
Send a message via AIM to slavik262
Since my explanation is pretty thorough and has little to do specifically with camera code, I've posted it here:
http://www.chiefdelphi.com/forums/sh...ad.php?t=82398
Share and enjoy.
Unread 18-02-2010, 06:56
charrisTTI charrisTTI is offline
Ramblin' Wreck
AKA: Charles Harris
FRC #0623
charrisTTI has a spectacular aura aboutcharrisTTI has a spectacular aura about
Send a message via AIM to charrisTTI
We are using latest udpates and programming in java. When testing tracking yesterday, we observed that the response time of the robot to the movement of the target got worse, the longer the program ran. After bootup, tracking response and image update were excellent. The more tracking cycles that were initiated, the worse the performance got; to the point where the robot would no longer track. On the drivers station we could see that the target was being tracked but with a significant delay as indicated by when the "locked on" circles were drawns around the target.
FRC 623 2003,2004,2005,2006,2007,2008, 2009, 2010, 2011
FRC 1900 2007
FVC 60 and 193 2006
FVC 3271 2007
FTC 226 and 369 2008, 2009, 2010, 2011
FTC 3806 2010
Unread 18-02-2010, 07:24
gvarndell's Avatar
gvarndell gvarndell is offline
Software Engineer
AKA: Addi's and Georgie's Dad
FRC #1629 (GaCo)
Team Role: Parent
gvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond repute
Piggy-backing on an existing C++ thread, when you're using Java, even though the problem you're asking about is similar, is not likely to get you the help you need.
Consider posting to the Java sub-forum instead?
Robots never, ever, ever, ever break -- The Robot Repairman (Backyardigans)
2010 FRC Camera Live Feed Lag ideasrule Programming 23 11-02-2010 02:33
2010 Camera and vision problems. s133p Programming 76 08-02-2010 21:35
Vision Tracking Camera picking up too much... taoistconvert Programming 8 24-01-2010 22:19
[not-FIRST] Camera Image Processing Greg Marra Programming 11 11-03-2008 21:10
