Go to Post Engineering is a balance between best performance, best cost, and best use of time. - GeorgeTheEng [more]
Unread 11-02-2010, 07:23
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
Java Tutorial...?
I know a little about java but, does anyone know where to get a video tutorial?
Unread 11-02-2010, 17:06
Thomas4019 Thomas4019 is offline
FRC #3006
Thomas4019 is an unknown quantity at this point
Re: Java Tutorial...?
I don't know where any video tutorials are but here is a popular java tutorial.
http://java.sun.com/docs/books/tutorial/java/index.html
It's a little hard to use but there is some great content in it.
Also The Really Big Index is useful when looking for help with a specific Java Construct.
Thomas Hansen
Team 3006
Unread 11-02-2010, 21:15
Lord_Jeremy's Avatar
Lord_Jeremy Lord_Jeremy is offline
Lord_Jeremy the Procrastinator
AKA: Jeremy Agostino
FRC #1546 (Chaos Inc.)
Team Role: Electrical
Lord_Jeremy is an unknown quantity at this point
Send a message via ICQ to Lord_Jeremy Send a message via AIM to Lord_Jeremy Send a message via MSN to Lord_Jeremy Send a message via Yahoo to Lord_Jeremy
If you gave more information about what you're having problems with or what you need help with I'm sure we could give you more specific advice. If you've ever taken a Java class then I'm sure you've worked with Javadoc. If you haven't then it's pretty easy to figure out. In the "sunspotfrcsdk" directory (I believe it's in Program Files on a PC) there's a folder called doc and inside that is javadoc. In the javadoc directory open up index.html to access the specific on how the WPILibJ classes work. Also, netbeans with the FRC plugins contains a bunch of examples for controlling the robot. Use the New Project button to access them. Good luck!
EDIT:
Actually it's not in Program Files apparently, according to this post.
Compiling...
Compiling...
**FIRST EMAIL**/Java and Orbit Balls *****JAVA DISCUSSION*** Pjohn1959 Programming 37 31-08-2009 15:55
ProEngineer Tutorial ida_noeman Inventor 0 20-01-2007 13:06
making of a tutorial Nimmy 3D Animation and Competition 1 31-03-2006 11:47
Tutorial Sites Mike IT / Communications 2 20-05-2005 00:00
PHP Tutorial AIBob Website Design/Showcase 0 30-01-2005 23:16
