Re: Joystick Problem
when you re-image the cRio, you delete all existing code on it.
go to labview (assuming thats what you are using) and redeploy the code... it should work then. just deploy the code from whatever software you are using and it should work |
| Joystick Communication Problem | mechatronics | NI LabVIEW | 4 | 03-02-2010 20:25 |
| Problem with the joystick | Asmos | NI LabVIEW | 5 | 23-01-2009 09:40 |
| Joystick problem | Team_136 | Control System | 0 | 14-01-2009 16:02 |
| Single joystick control problem | Mr. Van | Programming | 7 | 23-11-2004 09:10 |
| joystick problem | archiver | 2000 | 12 | 23-06-2002 23:08 |
