Go to Post I have yet to see an error where disabling the watchdog was the correct decision. - EricVanWyk [more]
Unread 11-02-2010, 10:46
The Last Don's Avatar
The Last Don The Last Don is offline
Illegal Immigrant
AKA: Alexander Calderon
FRC #2647 (North2 D2)
The Last Don is an unknown quantity at this point
Send a message via MSN to The Last Don
Joystick Problem
Hello Im a Programer for team 2647. Im having trouble with the joystick. I have followed the manual where we have to upload the example program into the crio. The first time the joystick had comunication with the jaguars and motors. The second I uploaded the new image, The joystick stop communicating. Is there any solution to this problem?
Unread 11-02-2010, 10:55
samir13k samir13k is offline
AKA: Samir Shaikh
FRC #4329
samir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant future
Send a message via AIM to samir13k Send a message via MSN to samir13k
Re: Joystick Problem
when you re-image the cRio, you delete all existing code on it.
go to labview (assuming thats what you are using) and redeploy the code... it should work then.
just deploy the code from whatever software you are using and it should work
Unread 13-02-2010, 13:13
Illegal Immigrant
Thank you for your help. IT WORKS
Joystick Communication Problem mechatronics NI LabVIEW 4 03-02-2010 20:25
Problem with the joystick Asmos NI LabVIEW 5 23-01-2009 09:40
Joystick problem Team_136 Control System 0 14-01-2009 16:02
Single joystick control problem Mr. Van Programming 7 23-11-2004 09:10
joystick problem archiver 2000 12 23-06-2002 23:08
