Go to Post If you are stupid about this and violate the rules, and thereby cause your alliance to lose a match, then your alliance partners will gang up on you and violate your robot. - dlavery [more]
Unread 11-02-2010, 11:23
Patrick Levy Patrick Levy is offline
FRC #3202
Patrick Levy is an unknown quantity at this point
Incorporating Our Code Into the Framework
We've got our programming written to do exactly what we want but did not use the Framework supplied by FRC.
1. Are we required to incorporate our code into the FRC Framework?
2. If so, how do we do it? We tried to write the same coding inside the framework supplied by FRC but it failed. We could upload to the cRIO but we got no response when we tried to operate the robot.
Thanks!
Patrick Levy
Harding High School
Team 3202
Unread 11-02-2010, 11:48
Re: Incorporating Our Code Into the Framework
It pretty much depends on how you've written your code as to how to integrate it into the framework. We'd have to see it to give recommendations.
There are some basic elements provided in the framework that you'd need to implement in your code to be able to use it as is.
For instance, you need to add the Driver Station communication, e.g., StartCom.
Putting the Compressor into the framework Team2339 NI LabVIEW 2 31-01-2009 19:32
our own allternative code for the cmu camera Gili Programming 16 17-02-2006 00:16
how to convert Easy C code into real code? TheHolyLancer Programming 1 29-01-2006 09:09
Bringing in Navigate.zip into the Default code alexrobotics Programming 1 24-02-2004 21:42
