Go to Post The closest thing to "Senior Mentor" we have is "Team Grandma". :) - Alan Anderson [more]
Unread 11-02-2010, 10:50
PlaidPillagers's Avatar
PlaidPillagers PlaidPillagers is offline
FRC #2538 (Plaid Pillagers)
PlaidPillagers is an unknown quantity at this point
Help Reading Joystick button Values
I'm programming our robot in C++, but there is a rookie team in our area to which I am currently providing assistance, and I can't figure out how to read a button value in LabView.
Sorry to ask such a trivial question, but thanks a bunch!
-Matt
Team 2538
Plaid Pillagers
Morris, Minnesota
Rookie Year 2008
Unread 11-02-2010, 11:27
Re: Help Reading Joystick button Values
Using a Joystick Get...
  • Hover over the Joystick Get icon and you'll see three outputs on the right side. The bottom output is for buttons.
  • Put your curser on the button output, right-click and choose Cluster, Class, & Variant Palette -> Unbundle by Name (it's the first choice)
  • Place the box you get and wire it to the button output on Joystick Get
  • You'll see Button 1 if you did it right. That can be switched to any other button or the box can be expanded to show multiple buttons.
  • The button output can then be wired someplace else that uses the value or displays it.
ID:	8618  Click image for larger version
Reading Robot values during a match jmanela NI LabVIEW 2 07-03-2009 19:58
Joystick Button Motor!!! HELP!!! furiousgeorge Programming 3 07-02-2009 22:57
Joystick Button Programming in Labview Help Needed domoarigato NI LabVIEW 11 28-01-2009 10:55
Reading Joystick Values Help FearlessLeader C/C++ 5 17-01-2009 23:33
Joystick values (?) beefy1 Programming 1 23-12-2008 11:26
