Go to Post You have accomplished and learned more in the past six weeks than...a majority of people in the country. Be proud of your machine. Don't kick it to the gutter. Stand behind it. Believe in it. Give it your all. Take pride in your robot. :) - sanddrag [more]
Unread 11-02-2010, 10:56
3195mentor 3195mentor is offline
I'm the original L337 N1nj4!
AKA: Jason
FRC #3195 (RoboNinjas)
3195mentor has a spectacular aura about3195mentor has a spectacular aura about3195mentor has a spectacular aura about
Unhappy cRio not detected...
Hey everyone, I'm the lead mentor for the RoboNinjas, a rookie team, and we are pretty much in dire need of help
we've only just recently managed to pull most of the electrical components together and have a somewhat stable test layout ready to go, however after having spent several days configuring the router, adapter, cRio, etc... when it came down to testing the cRio we were unable to detect it. i confirmed that the gaming adapter works and is detected by the router, and the "ethernet" lights are flashing on both the cRio and the adapter, however the control station does not detect the cRio.
we have already tried re-imaging the cRio, uploaded some coding via labview, reset the cRio and re-imaged again, reset the router / adapter / etc... and still no good.
are we missing something?
Unread 11-02-2010, 11:15
Racer26 Racer26 is offline
Re: cRio not detected...
Have you set your team number in the driver station software?
From the laptop, can you ping 10.31.95.2 and get a response?
Unread 11-02-2010, 11:33
AKA: Jason
we did set the driver station, but i won't be able to test the ping until later this afternoon. would you mind writing out the next steps for both scenarios (being able to ping and not being able to ping x.x.x.2)?
thanks for the help!
Unread 11-02-2010, 11:39
If you can ping, then your network is setup properly, and you should be able to see it. Similarly, if you can flash code into it, then this is working. There could still be an issue with a firewall or similar.
If you can't ping, its an issue with your network setup.
Unread 11-02-2010, 11:50
AKA: Jason
we flashed the code directly to the cRio using a crossover cable.
Unread 11-02-2010, 12:41
disable your wired adapter. the IP stack on windows boxes gets confused when it has two adapters on the same subnet
Unread 12-02-2010, 01:29
AKA: Jason
Re: cRio not detected... (Solution)
So today i had my students take another look at all the documentation and wiring. one of the students found what the issue was almost immediately... apparently when i went to test the connectivity on the cRio myself, i had plugged the ethernet cable into port 2 instead of port one (D'OH!!)
thanks for the help though, i'm glad to know someone is looking out for us rookies (even when the mentor himself has a rookie moment)
cRIO not turning on!!! MHSrobotics2853 Electrical 14 18-02-2010 08:58
cRIO Not Working?!? JohnFogarty Control System 2 17-01-2010 08:33
Errors in Diagnostics: I/O unit not detected ellisk Programming 5 16-01-2010 00:25
cRio not working...? Jack Gillespie Programming 22 13-02-2009 13:07
CRio Not Responding Shadow_Cat NI LabVIEW 7 13-02-2009 08:12
