Go to Post ...and then at the end they interviewed this 5 year old on his favorite part (of the fair): "I liked the robot" - Jessica Boucher [more]
Unread 10-02-2010, 00:13
Gamer930's Avatar
Gamer930 Gamer930 is offline
Team 930 and 171 Alumni
AKA: Justin
Gamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to behold
Camera Instance Problem
We are working on trying to get the Camera to work in Windriver C++ I have gone through and it seems our problem is different then others.
DS Version: 2010.01.06.00 (which is update 2 I can see the Gyro Dial on dashboard)
cRIO Image: C-2010_v19
I have included #include "Vision/AxisCamera.h" at the beginning of code.
Followed the instructions on page 58 of 2-2010FRCControl%20System-Getting%20Started-Rev-0.7.pdf
Our problem is when we make an instance of AxisCamera using the following code we get communication to the driver station but says "No Robot Code". If I comment out the GetInstance() line it everything runs perfect.
		//printf("Getting camera instance\n");
		AxisCamera &camera = AxisCamera::GetInstance();
		//printf("Setting camera parameters\n");
		//camera.WriteResolution(AxisCamera::kResolution_320x240);
		//camera.WriteCompression(20);
		//camera.WriteBrightness(0);
		GetWatchdog().SetEnabled(true);
		while (IsOperatorControl())
			GetWatchdog().Feed();
Note: I have no other vision code in the code except for what is shown and the include statement at beginning.
We have updated Windriver to "C/C++ Team Update 4.2 2/8/2010"
2010 to Present, Scorekeeper/Field Power Volunteer for FRC/FTC/FLL
2005 - 2010, Team 171 College Mentor
2002 - 2005, Team 930 Student
Unread 10-02-2010, 10:14
Zme Zme is offline
FRC #2619
Zme is on a distinguished road
Re: Camera Instance Problem
check the council out it should give you some indication as to whats going on.
you might also want to give the camera some time to boot before you try doing anything with it (once you get this code working that is)
Unread 10-02-2010, 18:48
Gamer930's Avatar
AKA: Justin
Unresolved Symbols List:
is the message I'm getting. . I have tried to put a Wait in front of the GetInstance and everything I try I get the same results. . .
attached is the actual error window
Unread 11-02-2010, 01:33
heydowns's Avatar
heydowns heydowns is offline
AKA: Jeff Downs
FRC #1511 (Rolling Thunder)
heydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond repute
Unresolved symbol means (in this case) that the code implementing the function call (AxisCamera::GetInstance()) is missing (from the WPILib library).
Is this with the most recent WPILib C++ update (02-08)?
We have this problem too, it seems the latest update has some issues in this regard.
See this thread on the official usfirst.org forums for the problem report and description, as well as a workaround, and hopefully an announcement of an updated release in the near future:
http://forums.usfirst.org/showthread.php?t=14573
Unread 11-02-2010, 09:33
Gamer930's Avatar
AKA: Justin
Called NI and they were unaware of any new Library errors . . . They wanted me to change to Labview and download the Labview default code on while I was on Hold. . . .
Did that and everything worked great. .
So there is forsure yet another error in the WPI Default Code/Library by the sounds of things and comments from other teams
Seriously considering just switching back to Labview. . . . We did Labview last year but grew to like Windriver in the off season.
Unread 11-02-2010, 11:45
Originally Posted by heydowns View Post
...it seems the latest update has some issues in this regard.
Those working on the issue seem to think it's a compiler (or perhaps linker) bug that is being brought out by the particular contents of the library. There are workarounds (as mentioned in the thread you linked to), and there will likely be an update that makes the bug stop surfacing.
Unread 11-02-2010, 14:12
heydowns's Avatar
AKA: Jeff Downs
That's odd, considering I took the stock WR suite and built the stock WPILib sources (to produce the workaround lib image linked above).
Do you have more details on said bug?
Unread 12-02-2010, 07:01
Kyledoo Kyledoo is offline
FRC #2603
Kyledoo is an unknown quantity at this point
Any idea when the new library will come out?
I removed all of our code that uses DriverStationLCD and we still had the problem.
Unread 12-02-2010, 12:49
pafwl pafwl is offline
Franciose
AKA: Frank Larkin
FRC #0272 (Cyber Crusaders)
pafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud of
I am having that problem too. I installed the update (4.2) to fix my DashboardLCD which worked great but it broke the camera. I removed the camera references and I am good.
I updated the thread we were on so I was hoping that Brad might have seen it.
Right now with all the camera problems it is "dead to me" so I am good.
I am planning on using Gyro directions for targetting. More reliable.
If the camera ever gets fixed I may go back but I am working very hard not to.
Unread 12-02-2010, 15:24
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
did you try rebuilding? [right click project]>Rebuild
Watchdog.Kill();
Camera problem ijk90825 Technical Discussion 1 28-01-2009 01:35
Instance relay Team_486 Programming 0 28-03-2007 09:56
Camera Problem ta1234 Programming 1 29-01-2007 09:38
camera problem miscar Programming 2 23-01-2005 12:06
Camera Problem n_0163 Electrical 3 14-01-2005 21:10
