Go to Post I have died and gone to heaven. :) - dlavery [more]
Unread 06-02-2010, 14:40
Jessi-Team 2156's Avatar
Jessi-Team 2156 Jessi-Team 2156 is offline
2156 Sacramento!!
AKA: Jessi Hageman
FRC #2156 (Wire Freaks)
Jessi-Team 2156 is an unknown quantity at this point
Exclamation How do you code the compressor?
please help!
Unread 06-02-2010, 14:47
Michael DiRamio Michael DiRamio is offline
FRC #1114 (Simbotics)
Michael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond repute
Re: How do you code the compressor?
What programming language are you using?
Unread 10-02-2010, 11:27
ericand's Avatar
ericand ericand is offline
AKA: Eric Anderson
FRC #3765 (Terrabots)
ericand is a jewel in the roughericand is a jewel in the roughericand is a jewel in the rough
The C++ compressor class works well. You just need to tell it the digital I/O pin that you read the pressure switch from and which relay to turn on/off to charge the system when needed.
This class is a standard part of the WPI lib and is covered in the WPI documentation.
Unread 10-02-2010, 18:20
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
why don't they make it a closed, automatic system within the compressor? it would make thing much easier, and save cRio processor power, and eliminate the need to program the compressor, and probably make inspection easier for FIRST volunteers.
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 11-02-2010, 11:01
Numbers's Avatar
Numbers Numbers is offline
Cyberdemon
FRC #3238 (Team Red)
Numbers is an unknown quantity at this point
Send a message via MSN to Numbers
You mean we can't do that?
Currently, we just have our analog pressure switch wired to battery terminals and a spike relay to automatically turn on the compressor with no programming.
Unread 11-02-2010, 11:13
Racer26 Racer26 is offline
No, you cant. The sensor is not allowed to directly affect power pathways between the Spike and the compressor.
You must wire the sensor to a digital input, and use that input in your code to switch the compressor on and off.
I've always thought this was silly too, but maybe there's a reason for it.
Unread 11-02-2010, 11:49
What you describe is forbidden by Rule <R78>:
<R78> The Nason pressure switch must be connected to the high-pressure side of the pneumatic circuit (i.e. prior to the pressure regulator) to sense the “stored” pressure of the circuit. The two wires from the pressure switch must be connected directly to a digital input and ground port on the Digital Sidecar, and the cRIO-FRC must be programmed to sense the state of the switch and operate the relay module that powers the compressor to prevent over-pressuring the system.
I don't know why your approach is not allowed. Perhaps someone with further insight could shed some light.
Unread 11-02-2010, 12:11
Taking the cRIO out of the loop removes the ability to turn off the compressor when the robot is disabled.
<R78> is clear and unambiguous.
Unread 11-02-2010, 12:26
I'm not suggesting to take the cRIO out of the loop, but why is it forbidden to have cRIO->Spike->Pressure Switch (its NC, so this works)->Compressor.
In 2003 this is how we wired it till we got to competition and told to change.
I don't understand why this configuration has always been disallowed... Its functionally identical, and there is no possibility for code to screw up.
Unread 11-02-2010, 12:38
The Nason pressure switch is rated for only 5 amps, nowhere near the current required by the compressor.
Unread 11-02-2010, 12:41
That sounds like a good reason. The only downside might be that the prevention of over-pressurization, which is the clearly stated intent of the Rule, is made less robust by including so many more components in the loop.
Of course, one might argue that the pressure-relief valve mitigates this concern. Unless, of course, the "factory pre-calibrated" pressure relief valve is in fact not properly calibrated as-received (as some teams have discovered).
With Alan's clarification of the likely intent of the rule, it certainly seems like a good rule, all things considered.
The rule is completely clear and unambiguous as to what is required.
Unread 11-02-2010, 13:01
That makes sense. Interesting that it worked for us though... guess it would dramatically shorten the lifespan of the switch / leave you open to risks of the switch welding itself or something.
I've seen things like that happen before. On my race car I have a switch on the radiator fans. The switch is rated for 10A (the biggest switch I could find without going online to a specialty supplier), and the fans pull 20-40A. Switch works, but on 2 instances has ceased to function. I thought about replacing it with an old automotive relay or something, but never got around to it. We hadn't realized what happened at first until I thought of the current draw of the motors, and the rating on the switch.
Unread 11-02-2010, 13:35
Omar's Avatar
Omar Omar is offline
Omar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of light
It's a SAFTY issue.
When the field control system shuts down the competition, it will shut down everything including the compressor
When the robot is disabled, all OUTPUTS are disabled including the compressor.
Don’t want a compressor kicking on and pressurizing a line and possible kicking unexpectedly>
Omar
Omar
Unread 11-02-2010, 15:14
Omar, with the system I described, FMS will still be able to shut it down, it just takes the cRIO out of the Overpressure-ShutDown condition.
Alan's answer about the 5A rating on the NASON switch was the part I didn't know about, and now it all makes sense to me.
How long can the battery run the compressor? rsisk Pneumatics 9 10-02-2010 12:13
Compressor Code causes No Robot Code Error sircedric4 C/C++ 25 03-02-2010 10:13
Code to have speed of motors dependent on how hard you push the joystick JoJo5 Programming 15 06-02-2007 12:35
Default code and the Compressor Matthew_H Programming 16 07-02-2005 07:19
How long does it take you to load the default code? vegasmcse Robotics Education and Curriculum 10 03-11-2003 21:41
