Go to Post Are you prepared to be a team member? - JaneYoung [more]
Unread 11-02-2010, 14:26
May_Walter's Avatar
May_Walter May_Walter is offline
Artemis #3083
FRC #3083 (Artemis)
May_Walter is an unknown quantity at this point
Tower question?
Hello, in the manual it says that the PLATFORM is 44 inches wide and 26" deep, which kinda means that if a robot is on the platform, the others cannot climb the tower, since the robots will be 38"+bumpers...
and in the drawing (GE-10028) it says 39"..
am I tired enough to be so wrong or are we in trouble?
Team ARTEMIS - #3083 - The Sky Isn't The Limit Anymore!
2011- FRC Team Captain and Coach, FLL mentor & Ref. Semi-Finalists, Motorola Quality Award, Star of the Day.
2010 - FRC Team Captain and Coach, Engineering Inspiration Award, UL Industrial Safety Award
2009 - Coach, Judges Award, Finalists w/ 3075 & 1690
Unread 11-02-2010, 14:42
Jones571's Avatar
Jones571 Jones571 is offline
AKA: Corey
FRC #0571 (Paragon)
Jones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud of
Send a message via AIM to Jones571
Re: Tower question?
The GDC has already stated that the dimensions in the field plans are the ones to go by. I would search for a link but it takes to much time on the iPhone
Unread 11-02-2010, 14:46
May_Walter's Avatar
Artemis #3083
FRC #3083 (Artemis)
Re: Tower question?
so the tower & platform dimentions are 39*39"? 100% sure?
Unread 11-02-2010, 14:51
Jones571's Avatar
AKA: Corey
FRC #0571 (Paragon)
Re: Tower question?
update #3
http://www.usfirst.org/uploadedFiles...Update%203.pdf
Unread 11-02-2010, 14:54
May_Walter's Avatar
Artemis #3083
FRC #3083 (Artemis)
Re: Tower question?
Originally Posted by Jones571 View Post
OKAY so now I'm even more confused
if a robot stands on the platform with its larger side (38") at the bump side, no other robot can climb?!
Unread 11-02-2010, 15:00
coldfusion1279 coldfusion1279 is offline
AKA: Mike
FRC #1279 (Cold Fusion)
coldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud of
Re: Tower question?
The long side is the side corresponding closely with the width of the tunnel. It wouldn't make sense for the tunnel to be 36" wide and the top of the platform to be 32" wide.
i.e. the top of the platform is not a square, and it could be difficult for a robot to elevated using the bar if there is a robot on the platform, and vice versa.
Hope this helps.
Cold Fusion's 10th Season
Unread 11-02-2010, 15:04
AKA: Mike
Re: Tower question?
I realize my reasoning for why the wide part of the platform is confusing, but the way I have explained the layout should be correct. 41 inches is from field-side to field-side, and 32 inches from driver station to driver station.
Jones571's Avatar
AKA: Corey
FRC #0571 (Paragon)
Re: Tower question?
never said the GDC tried to make anything easy now ur allinace will have to coordinate who hangs or elevates and in what order to make sure no one gets stuck on each other.
Tower Diagrams wwrobotics1452 General Forum 2 06-02-2010 16:24
Tunnel part of Tower GaryVoshol Rules/Strategy 10 19-01-2010 13:20
Question About the Tower Prepclub1939 Technical Discussion 1 10-01-2010 16:56
Tower Dimensions Kpchem General Forum 10 10-01-2010 15:42
Icy Tower DanDon Chit-Chat 16 02-11-2006 14:05
