Go to Post Remember: This is High School Competition. - rich2202 [more]
Unread 11-02-2010, 16:29
Re: Bumper Zone Contact
Originally Posted by Peter Matteson View Post
With no arms to push high on a robot with how does some one tip in this game in a level ground pushing match?
You don't need arms up high when your bumpers are up high.
Unread 11-02-2010, 16:42
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
But is your weight high?
If your CG is below your bumpers it shouldn't be easy to tip a robot. Tipping with arms was usually 2-3 feet off the ground, not 13 inches where the centerline of the bumper is.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 11-02-2010, 21:50
coldfusion1279 coldfusion1279 is offline
AKA: Mike
FRC #1279 (Cold Fusion)
coldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud of
I can guarantee that if a team has any sort of traction wheels (i.e. no HDPE, omni, or mecanums) and with the center of the bumpers being ~13" high that the robot can flip on flat ground no matter how low the cg is. Especially if the robot is in motion and shifting its momentum in different directions.
Cold Fusion's 10th Season
Unread 12-02-2010, 10:56
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Keep in mind, however... if the robot is designed to go over a bump, that means it can also be tipped at least 45 degrees before gravity will do the work to flip it over. That's a pretty big tip, and for a vast majority of robots, that will require prolonged contact and pushing outside of the bumper zone. The only caveat to this is, of course, if your CG is not properly centered in the robot. If it's significantly to one side, you'll be easier to tip.
opposing alliance zone? cbeavers6790 Rules/Strategy 7 13-01-2010 22:19
Bumper Zone Questions (was Misc. Questions) viperred396 General Forum 9 10-01-2010 12:09
Can the robot extend outside of the bumper zone. markulrich Rules/Strategy 15 08-01-2009 08:21
Bumper Zone Kilroy0846 Rules/Strategy 10 18-01-2008 15:49
null zone Xufer Programming 9 15-02-2004 12:54
