Go to Post "If you abuse the easy button, you become it." / "What does that mean?" / "We hit you and you say 'That was easy'" - ScoutingNerd175 [more]
Unread 11-02-2010, 16:31
aksharma's Avatar
aksharma aksharma is offline
FRC #2410 (Metal Mustang Robotics)
aksharma is an unknown quantity at this point
State Machines and Robot Framework
We have been trying to create a kicking mechanism in LabVIEW using multiple limit switches, and to do this we need a state machine. We have been trying to learn how to do this by watching the videos on LV Mastery, but they mention a Type Def called RobotData.ctl. We do not have this Type Def in our framework. We think it is in the Advanced Framework, but the main problem is that we do not have an option of using the Basic or Advanced Framework when we try to create a robot project. We have updated LabVIEW already, so we aren't really sure what is going on.
Is there a way to either create the state machine as described in the video without the Type Def or a way to get the option to have an advanced or basic framework?
Unread 11-02-2010, 17:54
Ziaholic's Avatar
Ziaholic Ziaholic is offline
Elec/SW Mentor
AKA: Marc
FRC #1164 (Project NEO)
Ziaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the rough
Re: State Machines and Robot Framework
That TypeDef is created by the Mastery Narrator in one of the TipJar videos. It is simply a bunch of different datatypes, in a cluster, converted to a typedef. It's a simple way to keep important data in one place, with the same names/labels/whatever.
Creating a typedef is not very difficult, but I don't have LV on my work PC and don't want to get one of the steps wrong. You basically right-click a cluster, go to its advanced properties page, and use a pull-down to change it into a TypeDef. Hopefully somebody else will reply with the detailed steps, or I can post again later when I get home.
Basic/Advanced doesn't apply this year ... it's all just the Framework.
There are 10 types of people. Those who understand binary, and those that do not.
Team #1164 - Project NEO Robotics
Unread 15-02-2010, 12:33
aksharma's Avatar
Thanks, that explanation helped us. We were able to figure it out.
Cruch Time Help! 3 LabVIEW Tutorial Videos: State Machines; Faster Code; Simulation LVMastery NI LabVIEW 11 09-02-2009 14:36
State Based Machines in LabView Greg Marra General Forum 0 11-11-2008 11:07
Hawaii Gov. Lingle State of State speech-FIRST and STEM MoeMom FIRST In the News... 0 29-01-2008 17:04
What machines are you using? (CNC, lathes, mills, 3-in-1 machines?) MrB Technical Discussion 17 03-11-2006 11:55
State Machines doyler Programming 7 11-01-2005 00:53
