Go to Post Pro safety tip: put a string through coil springs that is tied off securely on the robot frame. This will help prevent the spring from jumping out and killing an inspector if it snaps. - Ninja_Bait [more]
Unread 11-02-2010, 19:20
toastnbacon toastnbacon is offline
AKA: James
FRC #3169 (Saintborgs)
toastnbacon is a jewel in the roughtoastnbacon is a jewel in the roughtoastnbacon is a jewel in the roughtoastnbacon is a jewel in the rough
Re: Can wheels extend past the frame?
Thanks! We think we managed to fix the problem by simply moving the casters further inside the frame. Is it legal if they don't pass the frame Perimeter?
"This must be what going insane feels like."-Simon Tam, Firefly
Unread 11-02-2010, 19:22
As advised before, switch to ball casters instead if you can't purchase some Omni wheels.
Unread 11-02-2010, 19:24
GaryVoshol's Avatar
Cogito ergo arbitro
It's legal. Now read from some of the other posts here whether it's advisable or not.
(since 2004)
Unread 11-02-2010, 20:44
AKA: James
Yah, We thought about omni wheals, but we figured it would be to easy to push us around. I also proposed the ball casters to the team, but everyone thought the swivel casters would be fine. Could someone put the cons on here?
Unread 11-02-2010, 21:29
Chris is me's Avatar
AKA: Pinecone
Omni wheels and casters should be equally easy to be pushed by. What resistance to pushing would casters give you?
Unread 11-02-2010, 23:04
More to the point, Chris, is "what resistance to normal motion do swivel casters give you?" I've heard the horror stories of teams using them, only to have their robot go a little crazy when a caster didn't act like it should have.
I've also seen teams use ball casters with some success; most teams opt for omni wheels of some form instead of casters as you can get a little bit more forward "oomph" from omnis.
Short and sweet: swivel casters won't give you any less resistance to being pushed around; in fact, they might be the ones doing the pushing. Ball casters are better about not pushing you around. Omnis give you a little bit more forward/aft push (though not much).
Unread 12-02-2010, 00:51
Edoc'sil's Avatar
Edoc'sil Edoc'sil is offline
FRC #2531
Edoc'sil has a spectacular aura aboutEdoc'sil has a spectacular aura about
The big thing is a caster bot cant go straight to save its worthless life. The one place you cannot cut corners on in you bot is in your drivetrain. Fork over the cash for omnies. IMHO if it was legal a peg leg would be better then a caster.
Here lies a toppled god-
His fall was not a small one.
We did but build his pedestal,
A narrow and a tall one.
Unread 12-02-2010, 00:54
I don't see any rules preventing peg legs. They just can't have metal feet. OK, and they might cost too much...
Unread 12-02-2010, 10:23
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is online now
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Swivel casters give the worst of all scenarios. They give no traction (for pushing or resisting being pushed), and will (guaranteed) be facing in the wrong direction and cause your robot to not drive straight when starting to move. They do allow for fairly easy rotation of the robot. Cannot be powered. Swivel casters without suspension tend to get "shopping cart syndrome".
Ball casters also provide no traction,but do not interfere with the robot going in a straight line. They allow for much easier turning of the robot (easier than swivel casters). Cannot be powered.
Omnis provide traction (if powered) in one direction but not in the perpendicular direction. They allow for fairly easy rotation. They are expensive compared to casters.
Hope this helps.
___________________
- Tennyson, Ulysses
Unread 13-02-2010, 15:48
AKA: James
Thanks, this has all been a big help. Everyone else on my team still doesn't believe any of it, but I'm hoping when we drive around, they'll come to their senses.
Can the robot extend outside of the bumper zone. markulrich Rules/Strategy 15 08-01-2009 08:21
mecanum wheels on frame 7-11number1 Technical Discussion 8 06-02-2008 00:22
To extend or not to extend the ship date! FIXIT General Forum 61 17-02-2007 14:47
We can extend beyond the playing field with our ball-knocker-offer??? Natchez Rules/Strategy 35 19-03-2004 09:35
Can we ground our wires to the frame? mnkysp6353 Electrical 1 15-02-2002 20:47
