Go to Post "The purpose of computation is insight, not numbers." - Tom Ore [more]
Unread 11-02-2010, 19:45
RookieWookiez's Avatar
RookieWookiez RookieWookiez is offline
Scouting Student Leader
AKA: Dane Potter and Others
FRC #3138 (Innovators)
Team Role: Scout
RookieWookiez is an unknown quantity at this point
Accurate Field Dimensions
Okay, so me and my team have been trying to make part of the field with the balls for working on our autonomous (sorry if this is spelled wrong) program, but unfortunately we are unable to find accurate field dimentions. Can someone point us in the right direction for this?
Thanks in advance!
Unread 11-02-2010, 19:57
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Accurate Field Dimensions
You'll have to search through a lot of drawings to find exactly what you want, but they are all posted with the Manual on the FIRST website, Section 6 The Arena.
(since 2004)
Unread 11-02-2010, 20:14
Team Role: Scout
Okay, since I can't find it, I'll ask here. What I'm trying to find is the accurate detail of how far away the place where the ball placement square is away from each one of the sides of one of the sides of the square.
Unread 11-02-2010, 20:17
FE-00033, last page, is the Arena Layout and Marking sheet.
Unread 11-02-2010, 20:31
S117's Avatar
S117 S117 is offline
S117 is an unknown quantity at this point
I was asked by another team member to post this picture:
http://i48.tinypic.com/32zs67k.jpg
The red lines indicate the measurements which we need to know and they aren't explicitly labeled. Whether or not they're meant to be unknown (competition purposes) or whether or not we're simply not looking at the diagram right, this is what we need.
Unread 11-02-2010, 20:37
The horizontal red lines are easy. Simply add or subtract dimensions.
That line coming in at the top indicates the location of the center. If you know that, then you should be able to figure out distances from the driver's station and the bump...
Ditto for the vertical red lines, but you'll need to use the distance from the center line (labeled as 6' 8" in the drawing, which is where that picture came from).
Unread 11-02-2010, 20:49
S117's Avatar
After some mathematical deliberation (and some overcomplication) we have come upon the measurements. It seems as if our team is a little out of it tonight. Thank you for the advice.
Regolith Field Corner Dimensions MDiff Rules/Strategy 2 20-01-2009 07:14
Field Corner Dimensions Missing from Field Drawings? Don Wright General Forum 2 13-01-2009 19:57
[OCCRA]: vex field dimensions iwanttodunk OCCRA Q&A 1 04-10-2008 11:47
Dimensions of the Field duhoverdrive Technical Discussion 3 12-01-2008 12:35
Field Dimensions archiver 2000 11 23-06-2002 22:27
