Go to Post you know the FIRST season is never over . . it just pauses a while so you can get some sleep. - Stuart [more]
Unread 11-02-2010, 20:59
hccsteen hccsteen is offline
FRC #3160
hccsteen is an unknown quantity at this point
gear box with two motors
We have see pictures with two CIM motors on one gear box, what is the purpose for this setup?
Unread 11-02-2010, 21:00
EthanMiller EthanMiller is offline
Lead Programmer
AKA: Socks
FTC #4356 (The Zip Ties)
EthanMiller has a spectacular aura aboutEthanMiller has a spectacular aura aboutEthanMiller has a spectacular aura about
Re: gear box with two motors
1713 is using that setup - it gets a little more oomph from the CIMS to get us over the bump. Since we're not using but one other CIM, we hit our 5 with no need for more.
When all else fails, read the manual.
FRC 1713 K Island Gears 2009, 2010 (Not 2011 due to budget, hopefully 2012!) - Fingerlakes Regional
FTC 4356 The Zip Ties 2010-2011 Season - NNYRC (2010 9th seed).
Unread 11-02-2010, 21:03
FRC #3160
We are driving three wheels on each side with one motor on one gear box per side, would it be wise to try two motors on each side?
Unread 11-02-2010, 21:11
FRC #3160
Does using two motors to one gear box create greater or lesser load on the jaguar? Should we use the encoders on the gear box.
Unread 11-02-2010, 21:20
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
1. The load on the jaguars is the same. You shouldn't worry about it too much. You get theoretically double output torque though; more pushing power. In theory.
2. You should probably use encoders for Autonomous programming. You probably won't need them for Teleop.
Kettering Motorsports
svenw svenw is offline
FRC #3683
svenw is a jewel in the roughsvenw is a jewel in the roughsvenw is a jewel in the rough
you will need to use an extra jaguar for each motor. It depends how your drive set up is geared. If it is geared for high speeds and you have trouble pushing or climbing up the ramp then do it (as long as you have the weight). Just drive around, and if it seems a little gutless, add a motor.
Unread 11-02-2010, 21:23
Chris is me's Avatar
AKA: Pinecone
That's not quite right in theory.
There are two things that limit your pushing power, torque and traction. If you're limited by torque when pushing, then when pushing against immovable objects, you will draw a huge amount of current and trip circuit breakers. You can add more torque by changing gearing and / or adding motors, until you provide more torque than your wheels can ever exert. When this happens, when pushing against a wall, your wheels will slip. This is called traction limited.
Adding two motors allows your drive to become traction limited while running at higher speeds than a single motor.
pic: GEAR BOX with two speed ericwittlich Extra Discussion 6 19-07-2005 22:01
Need help with gear box bearings JIN General Forum 9 21-03-2005 20:10
Need help with gear box bearings JIN Kit & Additional Hardware 1 21-03-2005 12:46
Trouble with gear box dmellich Motors 6 17-01-2005 09:41
power of globe motor with gear box? Ken Leung Motors 5 21-11-2001 13:43
