Re: Mecanum Help Needed
Spoiler alert only go to this picture as a last resort it shows exactly the working holonomic drive (with a Logitech Dual Action Controller(you should only need to change the axes))
It is better to learn through testing and trying things out rather than copying. I repeat last resort only. |
What is this block? I can't find it in the palletes. (from your code, dana)
What this means is that if you put something in larger than 1 you will get out 1, if you put something in between 1 and -1 it will pass through unchanged and if you put in something smaller than -1 you will get out -1. |
| Mecanum Wheel Setup Help | Dylan5019 | NI LabVIEW | 16 | 10-02-2011 15:39 |
| Mecanum help in labview. | Sam2197 | NI LabVIEW | 1 | 08-02-2010 18:59 |
| Holonomic vs Mecanum Help!! | kSniper | Technical Discussion | 10 | 25-03-2008 16:57 |
| Mecanum Programming Help | Mars | Programming | 8 | 27-02-2008 15:41 |
| Mecanum Drive - Help | Smoking_Gun | Programming | 22 | 04-12-2007 20:51 |
