Go to Post I'm definitely not advocating PVC tanks. I'm just saying that if you're going to be an idiot, please be slightly less of an idiot. - FourPenguins [more]
Unread 11-02-2010, 22:51
AmandaMay AmandaMay is offline
lead programmer
FRC #2557 (SOTA Bots)
AmandaMay is an unknown quantity at this point
Pneumatics and drive together
We have a teleop sub vi in the main code. The teleop is now just being used for drive, but we tried to put our pneumatics code inside it. We first tried putting it in the code, but then just the pneumatics would work and the drive would not. Then we put the pneumatics in as a new sub vi and put it in our code. We had a lot more errors. pneumatics works alone and drive works alone. Why won't they work in the same project? We don't know what to do. Please help us
Unread 11-02-2010, 23:57
Re: Pneumatics and drive together
Post the vi's or post the one where you've tried to combine them and we'll help debug it.
Unread 12-02-2010, 00:02
bladetech932's Avatar
bladetech932 bladetech932 is offline
Programmer of awesome
AKA: Jon
FRC #0932 (Circuit Chargers)
bladetech932 is on a distinguished road
i can think of one thing that could be your problem if you are running the pneumatics on a relay
check the side car to make sure that the sidecars 5v,6v,and the one next to that are all lit
if not all 3 are lit fix the connection till you have all 3 lit
Unread 12-02-2010, 13:20
lead programmer
Alright, we figured out that the problem was a watchdog error. The compressor watchdog is not being fed so the compressor only turns on and off and does not run continuously. How do we feed the watchdog without creating a while loop. We attached a picture of our code.
Name:	Teleop VI IMAGE.jpg
Unread 12-02-2010, 13:26
That style is so last year
All your Open statements should be moved to Begin.vi where they really belong. What's happening is you are opening and closing all your devices 50 times a second by having them in Teleop.vi.
Here's how the compressor and solenoids should be used.
Starting the compressor this way actually spins off a task where it runs by itself as long as the robot is on without bothering anyone else.
Unread 12-02-2010, 13:29
lead programmer
Your link doesn't work.
Unread 12-02-2010, 13:31
Sorry, it's better now.
Unread 12-02-2010, 18:13
lead programmer
thank you. We'll let you know how it goes.
Unread 13-02-2010, 13:58
lead programmer
We are still having big problems, we used your code, but we have 2 solenoid valves on the same button. We are still having watchdog feed errors. Our compressor goes on and off.
Unread 13-02-2010, 14:02
lead programmer
In our diagnostics, it says the refnum we are trying to get does not exist, and it says error <code>-44047 occured at solenoid. lvlib:
Unread 13-02-2010, 14:07
That usually means that the name you typed in for the solenoid was mistyped.
I'd go to Begin.vi and copy the name of each device, then paste and wire it where you use it in Teleop.vi
Is the compressor going on and off rapidly?
Is there much pressure (by gauge reading) in the system when it's shutting off?
pic: Team 624 2009 Final and Prototype Robot together. RazorTip360 Extra Discussion 5 22-03-2009 21:56
tying together FIRST, VEX, and FLL sburro General Forum 10 08-02-2006 12:31
do tracks and wheels together make a better robot? gondorf Rumor Mill 31 16-01-2006 16:06
BS2p and GSM modem together. ice-egoz Programming 0 18-07-2004 23:47
Putting two and two together... Andy Grady General Forum 13 08-01-2004 18:29
