Go to Post I'll toss this out to stir up the pot: if you need double precision floats for your FRC software, you should re-think what you're doing. - Ether [more]
Unread 12-02-2010, 00:32
The Ars-sassin The Ars-sassin is offline
AKA: The Ars-sassin
FRC #2443 (N/A)
The Ars-sassin is an unknown quantity at this point
Piston Question
Does anyone know if it's allowed for our robot run an input/output pneumatic piston with only ONE hose on the piston (e.g-a piston with only an input hose or an output hose; the other would just be open).
Unread 12-02-2010, 00:35
Re: Piston Question
Why would you want to do that?
The rules don't specify that each piston has to have both ends connected, but I don't see a reason to have a 1-way piston, other than that something else would be pulling it back or it's a 1-shot application.
Unread 12-02-2010, 00:36
EthanMiller EthanMiller is offline
Lead Programmer
AKA: Socks
FTC #4356 (The Zip Ties)
EthanMiller has a spectacular aura aboutEthanMiller has a spectacular aura aboutEthanMiller has a spectacular aura about
Re: Piston Question
My team tried that, but it seemed air escaped, although for the life of me I don't know why. This is second hand, though. Feel free to pull out a hose and try it - it won't break anything.
As long as you unplug the hose when there's no pressure.
When all else fails, read the manual.
FRC 1713 K Island Gears 2009, 2010 (Not 2011 due to budget, hopefully 2012!) - Fingerlakes Regional
FTC 4356 The Zip Ties 2010-2011 Season - NNYRC (2010 9th seed).
Unread 12-02-2010, 00:50
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Piston Question
You will hear air coming out of the open port when the piston moves towards the open port and entering the port when the piston moves away from it.
If air is actually constantly leaking out of the open piston port I believe that the piston is broken as that sounds like a bad internal seal.
Regarding the original question, this is perfectly legal:
http://forums.usfirst.org/showthread.php?t=14218
Eric, it is often desirable to simply vent one port of a cylinder if it will already be returned by other means in order to save air. Our 2008 robot vented the retract port of our arm raising cylinder through a flow control valve and let gravity bring it down.
Unread 12-02-2010, 01:05
IndySam's Avatar
IndySam IndySam is online now
FRC #0829 (Digital Goats)
Re: Piston Question
It is perfectly fine to run a cylinder this way and I will wager you will see a lot of it this year.
Unread 12-02-2010, 09:49
Re: Piston Question
Because a pre-charged piston moves MUCH faster if it doesn't have to push a lot of air through a small exhaust hole.
You can make an impressive kicker this way.
http://www.chiefdelphi.com/forums/showpost.php?p=910176
Question about partial piston stroke itsme Pneumatics 10 30-01-2008 15:29
spring piston Matt21q General Forum 2 02-02-2007 23:44
spring piston? Matt21q Technical Discussion 2 02-02-2007 17:02
Piston question Spiffizzle Pneumatics 3 10-01-2007 21:17
Piston throw Alex N. Pneumatics 2 21-01-2004 21:19
