Go to Post I challenge the status quo - it's just me. - techhelpbb [more]
Unread 02-06-2010, 03:48 PM
toastnbacon toastnbacon is offline
AKA: James
FRC #3169 (Saintborgs)
toastnbacon is a jewel in the roughtoastnbacon is a jewel in the roughtoastnbacon is a jewel in the roughtoastnbacon is a jewel in the rough
Question Can wheels extend past the frame?
Our team is using casters in the back corners. Is it leagal if we turn and the casters turn past the frame perimeter?
"This must be what going insane feels like."-Simon Tam, Firefly
Unread 02-06-2010, 03:50 PM
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Re: Can wheels extend past the frame?
edit.
Unread 02-06-2010, 03:54 PM
AKA: James
Under very unusual circumstances, but normally no. Our frame is only 26" wide, though.
Unread 02-06-2010, 03:58 PM
If the casters go beyond the FRAME PERIMETER as defined in Section 8.2 of the Manual, then no, it is not legal. It is not one of the exceptions listed in <G30>.
FRAME PERIMETER – the polygon defined by the outer-most set of exterior vertices on the ROBOT (without the BUMPERS attached) that are within the BUMPER ZONE. To determine the FRAME PERIMETER, wrap a piece of string around the ROBOT at the level of the BUMPER ZONE - the string describes this polygon. Note: to permit a simplified definition of the FRAME PERIMETER and encourage a tight, robust connection between the BUMPERS and the FRAME PERIMETER, minor protrusions such as bolt heads, fastener ends, rivets, etc are excluded from the determination of the FRAME PERIMETER.
<G30> ROBOT Volume – During a MATCH, no part of the ROBOT shall extend outside the vertical projection of the FRAME PERIMETER, except as follows:[list of exceptions]
If the GDC isn't allowing bolt heads to extend past the FRAME PERIMETER, except in one very specific case, then I doubt that they'd allow a caster to do the same.
Now, if your lower frame is smaller than your upper frame, and the caster goes beyond that, but not beyond the FRAME PERIMETER, then you'd be OK.
Unread 02-06-2010, 06:36 PM
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
No they can't.
Please take it as friendly advice from someone who has used them before. I will never ever ever use casters on a FIRST robot again.
Unread 02-06-2010, 06:53 PM
Chris is me's Avatar
AKA: Pinecone
Use ball casters and your problem goes away completely. If you're going to use casters, use ball casters; swivel casters are such a hassle anyway.
Unread 02-06-2010, 07:15 PM
Rich Kressly's Avatar
Rich Kressly Rich Kressly is offline
Robot/STEM troublemaker since 2001
no team (Formerly 103 & 1712. Now run U.P. Robotics (other programs))
Rich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond repute
Agreed on all fronts...
Your situation is definitely illegal for 2010. Swivel casters on an FRC robot can lead to a lot of headache and heartache anyway. When I was with 103 we had a propensity to use them and had some negative results. They have since gone with ball casters on a few robots with MUCH better results. McMaster sells them for sure, but you might want to consult the teams that have used them to help with your selections.
technology, innovation, and invention without a social conscience will only allow us to destroy ourselves in more creative ways
Unread 02-06-2010, 07:25 PM
qwertyuiop[]\'s Avatar
qwertyuiop[]\ qwertyuiop[]\ is offline
Drive Train/Manipulator Team Leader
AKA: Steven Harris
FRC #0623 (Cougar Robotics)
qwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of light
dont even bother with casters. just use omniwheels if u can obtain them. they are even less of a hassle
"...i told you i wanted the left-handed screwdriver not the right-handed one..." always let the mentors get their morning coffee or else they start getting angry and making stuff up.
2005 NASA VCU Website Excellence Award, 2006 NASA VCU Website Excellence Award, 2006 Capital Clash, 2006 Delaware FVC Regional, 2007 Ramp Riot, 2007 Virginia FTC Regional, 2008 NASA VCU Regional, 2008 Battle of Baltimore, 2008 Virgina FTC Regional
Unread 02-11-2010, 07:20 PM
AKA: James
Thanks! We think we managed to fix the problem by simply moving the casters further inside the frame. Is it legal if they don't pass the frame Perimeter?
Unread 02-11-2010, 07:22 PM
As advised before, switch to ball casters instead if you can't purchase some Omni wheels.
Unread 02-11-2010, 07:24 PM
GaryVoshol's Avatar
Cogito ergo arbitro
It's legal. Now read from some of the other posts here whether it's advisable or not.
(since 2004)
Unread 02-11-2010, 08:44 PM
AKA: James
Yah, We thought about omni wheals, but we figured it would be to easy to push us around. I also proposed the ball casters to the team, but everyone thought the swivel casters would be fine. Could someone put the cons on here?
Unread 02-11-2010, 09:29 PM
AKA: Pinecone
Omni wheels and casters should be equally easy to be pushed by. What resistance to pushing would casters give you?
Unread 02-11-2010, 11:04 PM
More to the point, Chris, is "what resistance to normal motion do swivel casters give you?" I've heard the horror stories of teams using them, only to have their robot go a little crazy when a caster didn't act like it should have.
I've also seen teams use ball casters with some success; most teams opt for omni wheels of some form instead of casters as you can get a little bit more forward "oomph" from omnis.
Short and sweet: swivel casters won't give you any less resistance to being pushed around; in fact, they might be the ones doing the pushing. Ball casters are better about not pushing you around. Omnis give you a little bit more forward/aft push (though not much).
Unread 02-12-2010, 12:51 AM
Edoc'sil's Avatar
Edoc'sil Edoc'sil is offline
FRC #2531
Edoc'sil has a spectacular aura aboutEdoc'sil has a spectacular aura about
The big thing is a caster bot cant go straight to save its worthless life. The one place you cannot cut corners on in you bot is in your drivetrain. Fork over the cash for omnies. IMHO if it was legal a peg leg would be better then a caster.
Here lies a toppled god-
His fall was not a small one.
We did but build his pedestal,
A narrow and a tall one.
Can the robot extend outside of the bumper zone. markulrich Rules/Strategy 15 01-08-2009 08:21 AM
mecanum wheels on frame 7-11number1 Technical Discussion 8 02-06-2008 12:22 AM
To extend or not to extend the ship date! FIXIT General Forum 61 02-17-2007 02:47 PM
We can extend beyond the playing field with our ball-knocker-offer??? Natchez Rules/Strategy 35 03-19-2004 09:35 AM
Can we ground our wires to the frame? mnkysp6353 Electrical 1 02-15-2002 08:47 PM
