Go to Post CD threads are supposed to be about something? - Tim Baird [more]
Unread 12-02-2010, 00:58
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Withholding limits and GP
Originally Posted by iCurtis View Post
and you're control board was just the joysticks on a piece of paper, you could probably get a robot and controls in in under 40 lbs.
The Operator Console is exempt from the 40 lbs per <R38-A> (posted above).
Unread 12-02-2010, 01:12
I'd actually bet that it'll be noticed and fixed in an update. Just sayin'.
Unread 12-02-2010, 01:41
dtengineering's Avatar
AKA: Jason Brett
If your robot is under 40 pounds, not only CAN you keep it... but you DESERVE to keep it! I don't think we've ever built anything that came out under 110 pounds, let alone under 40!
The withholding limit is one of the rules, and it is not poor sportsmanship, or disrespectful to your fellow competitors to follow the rules.
And if you show up with a 40 pound robot, I don't care how good your drivers are, or how great your code is... you'll get pushed all over the place. As much as I enjoy taking rules to their logical conclusion, I think there are practical limits that make the "40 pound robot" scenario unlikely.
But PLEASE do USE the withholding allowance... it is a great way to make your robot better!
Jason
Unread 12-02-2010, 17:30
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
And, because it's relevant to this thread, does anyone know Speed Racer's weight? IIRC, Fezzik was 80-something lbs, so if you shipped the bumpers, and you're control board was just the joysticks on a piece of paper, you could probably get a robot and controls in in under 40 lbs.
($5 says that if/when submitted to the Q&A this approach will be deemed against the rules.)
I believe that it was under 40 lbs when I saw it at the regional.
I agree with icurtis that it will be deemed not legal. Holding back a robot would technically be a second robot which by the GDC's response in eric's post is against the intent of FIRST. I would suggest an identical practice robot.
1058 PVC Pirates 2016 - xxxx
Unread 12-02-2010, 17:38
I can't even believe this discussion is taking place. When someone asks you about FRC and how it works, do you not answer this way...
"On the first full weekend in January, every team in the world is given the game, a Kit of Parts and a set of rules. Every team then has six weeks and three days to design, build and test a robot at which point every team has to pack the robot into a shipping container and ship it to a warehouse. The next time the team sees their robot, will be their first event."
Modify as you need for bag and tag.
Unread 12-02-2010, 21:40
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
FRC #2200 (MMRambotics)
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
you'd have to catch us first.
Weighed the robot today, came in at 50lbs sans battery + bumpers, only gotta shave 10 lbs.
I have posted the question on the first Q+A
Adam Bochek - FRC 2200
http://www.mmrambotics.com
http://www.watchfirstnow.com
Unread 12-02-2010, 23:14
rsegrest's Avatar
rsegrest rsegrest is offline
@ least I'm OVER the rock THIS time
FRC #2582 (PantherBots)
rsegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant future
IMHO I agree with others that while this may not be deemed 'illegal' it certainly violates the principals and spirit of FIRST and the other teams that adhere to the 6 week rule. Speaking for our team we hold to the rules and keep only the control system etc as explicitly defined in the manual and use test systems for tweaking code. When we head for our regional we take only spare parts to repair and tools. We do not continue fabricating parts etc. Perhaps this is a disadvantage to our team that we do not do this however when we tell people six weeks we mean six weeks...once it's in the crate it's done until we get to Lone Star...so my answer would be that yes it violates the GP spirit of FIRST.
Impossible is just a big word for small men who find it easier to live in the world they've been given than to explore the power they have to change it. Impossible is not a fact. It's an opinion. Impossible is not a declaration. It's a dare Impossible is potential. Impossible is temporary. Impossible is nothing.
~ Unknown
Unread 13-02-2010, 05:35
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
If anybody seriously wants MORE work after six weeks exhaustion, let them have it. I'll be taking a nap.
Unread 13-02-2010, 07:06
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
I have two points to make:
1) If I saw a team, show up with an empty crate, and bring in their robot I would think they cheated and worked on the bot all the way up to the first regional. I wouldn't trust them.
2) If you bring in a 40 pound robot, as a fabricated part, I hope you don't break anything because you won't have any extra fabricated/spare parts.
*gets off soapbox*
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 13-02-2010, 14:14
Bochek's Avatar
AKA: Adam Bochek
I am hopeing the GDC finds it legal. but even if they do we will still ship SOME of our bot (need room to make some spare parts!)
Unread 14-02-2010, 10:05
Too Late! You are on the LRI top list now. Kidding of course. We don't keep a list.
Unread 15-02-2010, 18:31
Bochek's Avatar
AKA: Adam Bochek
Looks like the witholding allowance will be raised to 65lbs this year according to bill's blog.
Still no response from the GDC, how long does it usually take them to respond? I can barley wait for their answer.
Unread 15-02-2010, 18:41
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
They shipped those in the crate....
Unread 15-02-2010, 18:43
keehun's Avatar
keehun keehun is offline
Team Captain
AKA: Keehun Nam
FRC #2502 (EP Robotics)
keehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond repute
Send a message via AIM to keehun
Did the GDC just up the Withholding Limit?
Sorry if it was discussed before. I couldn't find it within this thread.
For by grace you have been saved through faith, and that not of yourselves; it is the gift of God, not of works, lest anyone should boast. -- Ephesians 2:8-9
2010: Quarter Finalist (MN 10,000 Lakes)
2010: Website Award (MN 10,000 Lakes)
2009: Quarter Finalist (MN 10,000 Lakes)
2009: GM Industrial Award (MN 10,000 Lakes)
Unread 15-02-2010, 18:48
Bochek's Avatar
AKA: Adam Bochek
waiting for the team update to come out in the next few days, but FRC Director posted on his blog explaining that due to weather causing a loss of build days to some teams the witholding limit will be raised to 65lbs.
Withholding Allowance nitneylion452 General Forum 2 07-02-2010 23:11
What's going in your Withholding Allowance? Trying to Help General Forum 79 24-02-2009 13:34
Spare batteries and Withholding Allowance Andy Brockway Rules/Strategy 2 20-02-2009 10:22
