Re: pic: Killer Bees Team 33 Teaser
Looks like what we were about to make tonight when our arm didn't pull the robot up. Then we just unjammed the arm
Bigger sprocket is working wonders too, lifted me up no problem in a power test. Scary as all get out...Something very slow with a ton of torque... Forklift? |
Following Dr. Joe's example , this set up should provide 34,780 Oz-in. of stall torque at about 35 RMP.
With 180 Lb-Ft of torque, lifting a robot is an easy proposition. ![]() |
Definitely makes for easy lifting if potentially... sedate. Given that a 153:1 gear down leaves your end effector turning at about 35 RPM. At 2 seconds per revolution, one would hope you're not planning on needing more than one revolution to complete a lift....
Where do you get the dewalt transmissions? Do you have to buy a whole drill?
Bruce |
http://www.dewaltservicenet.com/Products/DocumentView.aspx?productid=75463&typeId=19037&doc umentId=37924 You will need items 42 (outer case) and 61 (transmission assy) to get this to work. Follow the instructions in the Nothing But Dewalts whitepaper: http://www.chiefdelphi.com/media/papers/1592 Total cost for the transmission parts is $122.95. I have seen it cheaper elsewhere in the past though. |
We've somehow found a source for $55 DeWalt drills (the whole thing minus the batteries). I think. I'll ask our mentor tomorrow if you'd like.
#7
I think they are planning on lifting there whole alliance.
#8
Remember guys, power equals work over time. Losses neglected, any motor can move any load, it's just a matter of time.
#9
daltore, Yes if you could find a better price that would be great.
Thanks Bruce |
| pic: Team 33 Killer Bees - Buzz XIV | Eric Yahrmatter | Extra Discussion | 21 | 19-02-2009 14:11 |
| Thank You Killer Bees! | Rebecca Leung | Thanks and/or Congrats | 5 | 05-03-2008 23:33 |
| pic: What?! The Killer Bees are team 47? | Tim Baird | Extra Discussion | 1 | 15-07-2007 00:33 |
| Check out Team 33 "Killer Bees" Web Award submission | karbonator | Website Design/Showcase | 4 | 24-02-2006 00:24 |
| pic: KILLER BEES! | CD47-Bot | Extra Discussion | 2 | 18-10-2003 22:56 |
