Go to Post Could you explain this concept of a break from FIRST? Did my wife put you up to this? - Gary Dillard [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 12-02-2010, 01:19
Damaku250's Avatar
Damaku250 Damaku250 is offline
Electromechaneumatics guy
AKA: Craig Hoo
FRC #3161 (H.T. Tronic Titans)
Team Role: Electrical
Damaku250 is an unknown quantity at this point
Is there a specific purpose for the fans included in the KOP?
I was wondering if there was a specific purpose for the 2 large and 6 mini fans included in the KOP.
The mini ones look like they can just be hooked in parallel, and the bigger ones almost look like they can connect to a PWM port, but the positive and negative wires are reversed.
Are any other teams using these, and if so what for?
I thought it might be possible to hook these to a spike to cool off the compressor or motors that would be prone to overheating, but that's not really necessary/effective is it?
-Rookie All Star Award [WAT Regional 2010]
Electrical/Control systems, Mechanical and Pneumatics teams, Human player
Unread 12-02-2010, 01:22
Re: Is there a specific purpose for the fans included in the KOP?
The purpose is to cool components that you think need cooling. Unless, of course, you can come up with some creative method of using them to move air for other purposes.
It might be more necessary than you might think. I know 330 used some on their 2003 robot to cool the drill motors used in the drive, but not on their 2004 robot, even though the same motors were used in the same place. (They just weren't used all that much in the matches...)
Unread 12-02-2010, 01:26
Damaku250's Avatar
AKA: Craig Hoo
If we plan to use an FP with an AM planetary to run a roller, would it be a good idea to have something cooling the motor? Should we then connect the fans by PWM, Spike, or just straight to the PDB with a switch somewhere on the robot?
Unread 12-02-2010, 01:33
The FP has a built-in fan; make sure that you don't block the slots. If you'd like another fan, nothing's stopping you.
As for how to connect the fans, see the wiring and controls rules (and I think there's a Q&A on the topic somewhere too).
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
the FP motor has a little fan in it, be sure the vent holes at the gear end of the motor are open. As long as it does not get stalled it should be fine
Unread 12-02-2010, 07:46
Craig,
The large fan has a three pin connector that is not a PWM connector. Some fans are provided with a feedback/tach output. Some are provided with a rotation fail output. These outputs are provided so that they may be used in specific designs for cooling. I would suggest you do a search on the part number and check out the data sheets. They are pretty cool to read through and gain some additional knowledge.
Some teams who completely enclose their electronics, use these fans to force cool the enclosure.
Are wheels included in the NORMAL CONFIGURATION for the robot? Team 3270 Rules/Strategy 3 21-01-2010 23:27
For all the Billfred fans out there ROBOmasta Chit-Chat 5 16-02-2009 11:58
There arent many specific rules about the human player... Ashley Christine Rules/Strategy 16 12-01-2006 15:38
A question to all the Linkin Park fans out there Raven_Writer Chit-Chat 1 19-05-2004 11:46
For You "The Mole" Fans Out There... Joe Matt Chit-Chat 0 16-02-2002 22:26
