Go to Post Weren't you ever told Canada is backwards from the US? - Alex Cormier [more]
Unread 12-02-2010, 08:18
Re: Enabling yields one "Watchdog not fed" flash
If the +5 LED goes out, you probably have a power problem. Is the Digital Sidecar getting a good 12 volts from the Power Distribution board?
The first watchdog message you see might be coming from a timing glitch at the beginning of the camera code. If it only happens the one time, don't worry about it. The other occasional messages you see when you're on the Diagnostic tab are also something you don't need to worry about. (There might be a Driver Station software update that addresses them eventually.)
Watchdog not fed brianelite C/C++ 12 14-03-2010 14:43
"watchdog not fed" error Lumit NI LabVIEW 8 04-02-2010 18:45
Enabling the robot from "developer". lookitsnichole Programming 2 26-01-2010 21:14
Watchdog not fed ahudson Programming 1 22-01-2010 11:26
"Thunderbirds" Vs. "Team America" Which one will rule the box office? Elgin Clock Chit-Chat 3 07-09-2004 19:53
