Go to Post As we were lying the robot down to work on it "CAD me like one of your french robots" - 1uan [more]
Unread 12-02-2010, 09:10
cilginbilgin cilginbilgin is offline
FRC #2905
cilginbilgin is a jewel in the roughcilginbilgin is a jewel in the roughcilginbilgin is a jewel in the roughcilginbilgin is a jewel in the rough
Question Axis Camera Problem
We have a problem about camera.
We have already done everything about camera's IP adress and we have already uptaded the new Driver Station...
but we cannot see the camera image in the dashboard window (upper side of the driver station)...
What should we do???
Unread 12-02-2010, 09:41
EthanMiller EthanMiller is offline
Lead Programmer
AKA: Socks
FTC #4356 (The Zip Ties)
EthanMiller has a spectacular aura aboutEthanMiller has a spectacular aura aboutEthanMiller has a spectacular aura about
Re: Axis Camera Problem
Run the Driverstation update twice more - the first time, uninstall the product, then reinstall it again.
When all else fails, read the manual.
FRC 1713 K Island Gears 2009, 2010 (Not 2011 due to budget, hopefully 2012!) - Fingerlakes Regional
FTC 4356 The Zip Ties 2010-2011 Season - NNYRC (2010 9th seed).
Unread 12-02-2010, 10:19
Originally Posted by cilginbilgin View Post
We have already done everything about camera's IP adress...
The only thing you need to do with the camera is add a user with id FRC and password FRC. You shouldn't have had to do anything with the IP address. The cRIO looks for the camera at its default 192.168.0.90 address. If you have changed it to something else, set it back.
Unread 13-02-2010, 13:13
Mintaka3's Avatar
Mintaka3 Mintaka3 is offline
Mintaka3 is an unknown quantity at this point
Ok..I have installed several Axis cameras here at my office, and the first thing you should do is to reset the camera to factory (Factory Default)...read the manual and reset the camera.
Do the installation as per the manual, go to the router and set the ports, test the camera on-line with your local IP plus the port, for example: 192.168.1.120:8020
You should get the camera page and the picture on your screen.
If you don't see anything is because you need to go to your cameras menu, a set the port in there too: is usually set at port 80, you should change it to the new port, in this case 8020.
try again your camera's IP plus the port, you should get it now. If you're still having trouble let me know!
Java/Netbeans Camera Code for Classmate PC and Axis Camera joshholat Programming 1 23-01-2010 14:59
Axis Camera ehochstein Programming 2 21-02-2009 00:16
Axis Camera w/ Labview problem lamoreaux2198 Technical Discussion 2 14-01-2009 04:38
Axis cam problem keehun Programming 8 07-01-2009 11:32
axis camera - problem s0crates FRC Control System 11 16-12-2008 09:34
