Go to Post I'm not worried about the amount of Segways at a regoinal, I'd rather see them out in the real world than at a robotics competition. - Joe Matt [more]
Unread 12-02-2010, 10:11
zebrabots zebrabots is offline
FRC #2909
zebrabots is on a distinguished road
legal pnuematic solenoid
what is the legal pnuematic soleniod this year, we did not get one in the kit of parts and we need to order a few. also what is the part number and where should we order them?
Unread 12-02-2010, 10:14
Re: legal pnuematic solenoid
From <R72>
C. Solenoid valves. All such valves must have a maximum ⅛” NPT port diameter, and a maximum Cv of 0.32 (if non-KOP valves are used, the team will be required to provide part documentation validating that the valves meet these constraints). Solenoid valves that are rated for a maximum pressure that is less than 125psi rating mandated above are permitted, however if employed, an additional pressure relief valve must be added to the low pressure side of the main regulator. The additional relief valve must be set to a lower pressure than the maximum pressure rating for the solenoid valve.
You should have received one double solenoid valve in the KOP
Unread 12-02-2010, 10:21
FRC #2909
we did not recieve the one in the KOP, and we missed teh deadline to get it replaced, so that is why I am wanting the serial number and other information to order new ones.
Unread 12-02-2010, 10:34
See the 2010 FIRST Robotics Competition Manual and Related Documents page on the FIRST web site. Under Section 10 - The Kit of Parts there is a link to Where to get more which includes a URL for FESTO's "FIRST robotics program" support page.
Unread 12-02-2010, 10:35
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
Rather than try to duplicate the KOP solenoid, just pick out a legal one that is available. We are using this one from SMC:
VQZ2120K-6G1-N7
This is a vqz2000 series valve with a metal seal, Cv is .3 in one
direction, .32 in the other. Max pressure 145 PSI. It has 1/4" one touch
fittings on the work ports, 1/8" NPTF on the pressure and exhaust ports
and can be mounted on a manifold. It operates on 12 volts, and has lead wires attached to the coil (no plugs)
The K indicates high pressure, or a 145 PSI rating.
Finding this exact part may be a challenge, so look for one that is close. Ours is coming from Japan, with expediting, it takes a minimum of 10 days to get here
Former Mentor Team 1771
Former mentor Team 4509
Unread 12-02-2010, 10:36
FRC #2909
thanks so much!
"Is it legal to have more than one acuator on one solenoid?" fordchrist675 General Forum 7 09-02-2011 04:25
Solenoid not firing off Solenoid Breakout spooncwru Pneumatics 2 30-01-2010 17:46
2 SOLENOID BREAKOUTS? Legal? BaByGrL Pneumatics 1 19-01-2010 14:04
Pnuematic Question? AlexD744 Technical Discussion 2 27-05-2009 22:42
Pnuematic Claw neoshaakti Pneumatics 4 21-01-2008 14:44
