Go to Post You people are online way too early in the morning... - Beth Sweet [more]
Unread 12-02-2010, 12:36
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
1771's Pushing Power
After many weeks of building, our robot can drive!
http://www.youtube.com/watch?v=XlHAGVlojcs
Unread 12-02-2010, 12:42
Josh Drake's Avatar
Josh Drake Josh Drake is offline
Engineering Mentor
FRC #5403 (Aluminosity)
Josh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond repute
Re: 1771's Pushing Power
Looks similar in some aspects
Good luck at Peachtree.
07'-10' FRC 343
11'-12' FRC 2751
13'-14' FRC 3494
15'-16' FRC 5403
Unread 12-02-2010, 12:46
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Unfortunately we will not be in Palmetto. Hopefully we'll get the chance to see each other at the championship though.
Mentor 2415
Unread 12-02-2010, 12:48
RMS11's Avatar
RMS11 RMS11 is offline
Safety!!!!
AKA: Rick
FRC #2415 (WiredCats)
Team Role: Driver
RMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to behold
Send a message via AIM to RMS11
Looks sick guys!!! Do you have a 2Cim and 1FP transmission per side? Really nice setup!
2009 Peachtree Regional Champs
2009 Palmetto Regional Champs
2008 Peachtree Rookie All Star and Rookie Highest Seed
Unread 12-02-2010, 12:55
dtengineering's Avatar
AKA: Jason Brett
Nice! We're building a "plywood box" robot too. We're using a CNC router for our detail work... looks like you've got access to a laser cutter? Is it big enough to get a whole side of the robot in? Our CNC can only fit about half of one side panel so we have to take care repositioning and indexing everything... a bit of a pain.
As for the pushing force, although it looks like it is doing a great job of pushing, a measured value of 80 lbs is quite a bit lower than the thoeretical maximum pushing force for a robot. I know your team has been around for a while, so forgive me if you've already considered the following.
If you have wheels with roughtop tread, the specified coefficient of friction with carpet is 1.3. That means that a 150lb robot (including bumpers, battery, etc.) with proper gearing and all the weight on high friction drive wheels should be able to generate over 180 lbs of 'push'. Even a standard AndyMark type wheel should give you a coefficient of friction close to 1.0 and up to 150 pounds of pushing force.
Are you using four CIMs in your drive system? What gear ratio (including any sprocket reductions) are you using? If your motors are near stalling at 80 pounds of pushing force and you want to get even more, it may be possible.
Jason
AKA: Sean
Yes we do! From what I hear the team loves the set up. We also have 8wd with 1.25" wide roughtop treaded wheels and we are using timing belt instead of chain.
Mentor 2415
Unread 12-02-2010, 12:59
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
looks like the robot is only about 2/3 of it's final weight?
Beautiful chassis!
Unread 12-02-2010, 13:05
AKA: Sean
Im honestly not sure how they tested that pushing force but I know that value is off. They possibly were testing it on the tile which would explain the drop. It is geared right at 10.5 ft/sec with 4cims and 2fp's so we can definitely push more. Also in the picture it weighs 70ish lbs.
It was all cut by our sponsor on there laser which can handle a 48" by 48" sheet so yes it all fit on the machine. We are using baltic birch instead of okoume this year since its much easier to get and more durable at the expense of heavier weight.
Mentor 2415
Unread 12-02-2010, 13:06
Chris is me's Avatar
AKA: Pinecone
So THAT's why you really liked those 2791 chassis cutouts...
Hopefully sometime tomorrow we'll be able to post something like that. Cool to see you guys sticking with wood.
Unread 12-02-2010, 13:09
AKA: Sean
Ha you caught me. This scalloped design has been floating in my head and designs for about a year now and finally we got a chance to use it. I forgot to mention that we are using 4.5" wheels and the entire drivetrain including transmissions is under 6" in height from the floor. Needless to say we are not too worried about flipping.
Mentor 2415
Unread 12-02-2010, 13:11
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
I am so disappointed. I think some sc teams would love to test your mettle in Greenville on the 20th.
Unread 12-02-2010, 13:15
AKA: Sean
Believe me we would love to defend our title but there just wasnt enough money in the budget for palmetto this year. Hopefully we will fundraise more next year and be able to return.
Im still waiting to see some pics of your bot. I saw one shot on facebook but it doesnt reveal anything.
Mentor 2415
Unread 12-02-2010, 13:22
BSEE, MSEE, JD
AKA: employed
Brashier Middle College in simpsonville, sc on the 20th....you can get all the pictures you want, just bring the bot with you
Unread 12-02-2010, 13:40
Josh Drake's Avatar
Engineering Mentor
I have some details on 2815, but I will have to keep quiet or they will tell our secrets too. Stephen is talking about the SC scrimmage next weekend.
07'-10' FRC 343
11'-12' FRC 2751
13'-14' FRC 3494
15'-16' FRC 5403
1771's first ever team theme song mikelowry Chit-Chat 5 12-02-2010 12:09
1771's Jaguars mikelowry Robot Showcase 25 04-02-2010 12:54
Pushing Play Without Pushing Play Res0lu7ion 3D Animation and Competition 3 12-12-2008 15:05
Drivetrains: Pushing Power? Kims Robot Technical Discussion 6 15-01-2008 12:11
Pushing power with out breaker popping rlowerr_1 General Forum 13 23-07-2003 01:22
