Go to Post In any case, don't beat yourself up over it. Only 24 teams get to play in elimination rounds. Sometimes you're in the 24, and sometimes you aren't. - jgannon [more]
Unread 12-02-2010, 16:06
3p1c w1n 3p1c w1n is offline
FRC #1529
3p1c w1n is an unknown quantity at this point
Re: Labview Solenoid Programming
ok I set it to off when the case is false and error still pops up. I attached the error message.
Thanks for your help.
File Type: txt lol.txt (651 Bytes, 79 views)
Unread 12-02-2010, 16:14
Don't try to build the broken project. Just click the "run" arrow and LabVIEW will be able to show you where it is broken.
Unread 12-02-2010, 17:29
FRC #1529
Thanks for the help
I haven't gotten that stuff working yet but I did get the compressor running
Programming Double Solenoid? Brandon_L NI LabVIEW 13 14-02-2009 10:33
Solenoid Programming Issue. Dr. Manhattan Pneumatics 2 10-02-2009 17:42
solenoid programming holty531 Programming 0 10-02-2008 16:17
Programming a Solenoid Brigander Pneumatics 4 17-02-2007 14:06
Solenoid Programming duckshepherd Pneumatics 1 17-02-2003 09:15
