Go to Post We can build it... we have the technology...better than it was before... Better...stronger...faster.... more PINK - Barry Bonzack [more]
Unread 12-02-2010, 04:45
Noamr Noamr is offline
FRC #1574 (Miscar)
Noamr is an unknown quantity at this point
GetImage slowing down image processing.
I know there have been a few threads about the image processing speed, but I couldn't find a specific one about this. We noticed that even though our find circular targets vi takes an adequate amount of time, our get images vi inside the vision processing takes over 200ms! We tried raising our FPS rate but it didn't help.
We'd appreciate if anyone could check how long it taks on theirs or have any advice for how we could fix it.
Thanks,
Noam
MisCar 1574
Unread 12-02-2010, 07:20
Ziaholic's Avatar
Ziaholic Ziaholic is offline
Elec/SW Mentor
AKA: Marc
FRC #1164 (Project NEO)
Ziaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the rough
Re: GetImage slowing down image processing.
That's about the same thing we've found ... using the default code and default settings, we saw around 150 msec for Low resolution, around 250 msec for Medium resolution, and up to 500 msec for Hi resolution images.
You can improve those times by adjusting the parameters that feed into the Find Circles VI (like the search rectangle and quality parameters), but it'll always take longer than the 20 msec main loop within RobotMain.
Depending on your settings, you could have anywhere from 8 to 25 driver cycles in between target updates. The trick will be to write your Teleop or Auton code to be able to react accordingly when the target data is updated. If you act on the target data on every driver-cycle, you'll probably overshoot the target like we did at first.
We added some code to check and see if the target data has changed before we act on it. You can do this with either a feedback node or a shift register.
There are 10 types of people. Those who understand binary, and those that do not.
Team #1164 - Project NEO Robotics
Unread 12-02-2010, 08:36
FRC #1574 (Miscar)
Thanks for the reply!
But, actually I wasn't talking about that. We can deal with the 150ms for medium resolution. The problem isn't the find circular targets VI - it's with the Get Image VI. This takes up way more than it should according to the FPS we set. It has a wait function inside that sometimes waits for over 200ms to get new info from the camera! Did you check how much time it takes your whole vision processing VI to execute?(not just the find circular VI)
Unread 12-02-2010, 10:16
Ziaholic's Avatar
Elec/SW Mentor
AKA: Marc
We haven't gone into the timing of the overall image path. Call me lazy, but since they provided that timer for the FindCircles.VI, that's the only time that we've analyzed.
I'd have to poke around the GetImage.VI before I could offer detailed advice. Are you using the color image very much? The default code pulls out the greyscale soon after it enters that VI and that reduces the amount of data that has to get moved around or computed on.
A full color, full rez image is 640x480 (rez) x 32 (bit color) x 3 colors = 3.7 MB
Medium Rez = 920KB, and Low Rez is 230 KB. It takes time to move/copy/compute that much data.
Optimizing that VI will take some smarts ... and there will be a lower limit to the time it takes based on the size & depth of the image.
... and since this is an ethernet enabled web-cam, I believe that the "hidden" interface to the cRIO is simple HTML. This initial acquisition of the raw image could end up being the controlling bottleneck and we're powerless to tweak that.
I'll have some time on our proto-bot this weekend and will come back with some numbers over the next couple days.
Unread 12-02-2010, 18:42
What are the settings for the camera? You mention setting FPS, but have other settings changed? In particular, setting the compression very low can cause the camera to be quite late. Try setting the image size to medium and the compression to 20%.
If this helps, the issue seems to be with large(>16kB) allocation of memory on vxWorks to hold the compressed image. By setting the medium image compression to 20%, I was able to get much higher frame rate. I suspect that this may be causing the glitches you are seeing. Memory managers tend to have internal allocation thresholds that determine which pool of memory an allocation comes from. There can be odd timing differences when crossing these thresholds and different timing differences when reallocating blocks of memory from these different heaps. I haven't had a chance to find a workaround except to keep the image sizes in the fast range.
Greg McKaskle
Unread 14-02-2010, 14:32
FRC #1574 (Miscar)
Thanks for the replies
I tried raising the compression and it did help. However, I was wondering if it's not the same as lowering the resolution. Actually, lowering the resolution might even take less calculations than compression.
Unread 14-02-2010, 22:23
Try both to see which works better. Low resolution tends to blur things and lower scores. Obviously high compression affects results by adding noise.
Greg McKaskle
Slowing down a globe dboisvert Electrical 4 08-03-2009 15:30
Camera Slowing code down? Maxpower57 C/C++ 4 02-02-2009 20:57
Slowing down Camera drive turning Zalumaskov Programming 1 27-02-2005 10:11
Slowing Down Drive Motors Arc736UV Programming 5 24-01-2005 22:35
Is FIRST slowing down with it's updates! mtaman02 Regional Competitions 8 15-03-2004 23:25
