Go to Post My wife is in advertising, and uses a scary amount of math. They have to know how to target you and beat down your defenses, so that you buy that hamburger while driving that car while wearing those designer jeans to your favorite store. - Not2B [more]
Unread 12-02-2010, 17:24
3195mentor 3195mentor is offline
I'm the original L337 N1nj4!
AKA: Jason
FRC #3195 (RoboNinjas)
3195mentor has a spectacular aura about3195mentor has a spectacular aura about3195mentor has a spectacular aura about
Thumbs up "No Robot Code" error? plus other issues... (Resolved)
we've tried uploading the program to our cRio, however whenever we go to the driver station, we still see the "Robot Code" LED as red. it's not detecting our robot code even after deployment, any idea why?
we followed the video tutorial here:
http://decibel.ni.com/content/docs/DOC-3014
also, i don't know if this is related to the coding problem, but our motor controllers are not responding what so ever. we've tried both the victor and jaguar motors and both are responding the same way (just blinking, no change in pattern).
any help on this is appreciated.
--- we are using Labview; already updated firmware / driver + labview to latest. ---
**UPDATE** Issue has been resolved. see below for our ("oh duh" moment) resolution
Last edited by 3195mentor : 13-02-2010 at 00:18. Reason: issues were resolved! woohoo!
Unread 12-02-2010, 18:52
Re: "No Robot Code" error? plus other issues...
I didn't watch the tutorial, but there are two ways of getting code on the robot. For development, I'd recommend hitting the run arrow on the RobotMain VI. It will put up a dialog listing the work to do and any issues it runs into.
To put the code onto the robot for a competition, once you know your code works, you deploy and set the App as startup. You may not be doing the second step. Also, it should state that it needs to reboot the cRIO. You don't mention that step, so perhaps you are only deploying.
Greg McKaskle
Unread 13-02-2010, 00:17
AKA: Jason
Lightbulb Re: "No Robot Code" error? plus other issues... (RESOLVED)
Apparently the issue was the driver station...
nowhere in the documentation (at least that i could find) did it state that you had to run the driver station program along side the debugger/compiler... (start / all programs / FRC driver station). i was under the impression it would work by just hitting the little arrow button in the compiler when hooked directly to the cRio (little did i know...)
everything works now. got the code working (with a few changes between the tutorial's beta version and the most recent version). it's a very VERY basic program for just tank-drive movement... if any other rookie teams (who are still struggling with the coding in labview) want a copy of our template, just email me (see below) and i'll post a copy on here and / or email it to you.
Unread 13-02-2010, 08:20
Your original post said the "Robot Code" LED was red, so we naturally assumed you were running the Driver Station application. If you hadn't given that indication, you would quickly have been advised to run it exactly the way you figured out.
Error "IFI>Master Code Version: 8 " mecanumbot Programming 0 24-01-2010 01:30
"Code Error" with RegisterRepeatingTimer d235j Programming 4 27-02-2008 21:51
Persistent "no robot controller found" error 1594code Programming 12 20-02-2006 20:59
Screenshot of "code not understood" or similar error needed! Elgin Clock Programming 3 17-02-2006 22:06
Code error on RC after downloading "bells and whistles" version of Kevins camera code DanDon Programming 6 10-01-2006 18:07
