Go to Post Umm, guys, the stacking game was last year. Toss the Genia is much more appropriate for Aim High. - Greg Marra [more]
Unread 11-02-2010, 17:16
EthanMiller EthanMiller is offline
Lead Programmer
AKA: Socks
FTC #4356 (The Zip Ties)
EthanMiller has a spectacular aura aboutEthanMiller has a spectacular aura aboutEthanMiller has a spectacular aura about
Axis Camera to Dashboard
I'm fairly new to programming, and I'm my team's only programmer, with no mentors knowing any programming. So far I've been able to piece together some Java, but the camera is beyond me.
I've looked at the Javadocs for the Axis camera, and the Circle Tracker demo, but I really don't understand how it works. If anyone could explain that, and how to implement it (at least to the effect of outputting camera to the dashboard) and the basic idea of image processing, I would be really grateful.
Thanks!
When all else fails, read the manual.
FRC 1713 K Island Gears 2009, 2010 (Not 2011 due to budget, hopefully 2012!) - Fingerlakes Regional
FTC 4356 The Zip Ties 2010-2011 Season - NNYRC (2010 9th seed).
Unread 11-02-2010, 21:09
Lord_Jeremy's Avatar
Lord_Jeremy Lord_Jeremy is offline
Lord_Jeremy the Procrastinator
AKA: Jeremy Agostino
FRC #1546 (Chaos Inc.)
Team Role: Electrical
Lord_Jeremy is an unknown quantity at this point
Send a message via ICQ to Lord_Jeremy Send a message via AIM to Lord_Jeremy Send a message via MSN to Lord_Jeremy Send a message via Yahoo to Lord_Jeremy
Re: Axis Camera to Dashboard
Hey. Theoretically the camera should just show up on the dashboard when you call AxisCamera.getInstance(). At least, that's what I've read. You can see how it's done in the CircleTrackerDemo example code that's supplied in netbeans. Unfortunately, neither the example code nor a routine I've written seems to be written seems to be working for my team, we're investigating possible solutions. Anyway, I'm proficient in Java so if you need any help getting anything else working let me know.
Compiling...
Compiling...
Unread 11-02-2010, 21:12
Lead Programmer
AKA: Socks
Okay, thanks. I'll try that tomorrow. (And I really need to have a mockup bot in my basement...)
Unread 11-02-2010, 21:17
Tell me about it. I've written around 1500 lines of code that I have no way to test because the robot is yet to be wired.
Compiling...
Compiling...
Unread 11-02-2010, 21:44
synth3tk's Avatar
synth3tk synth3tk is offline
Volunteer / The Blue Alliance
AKA: David Thomas
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
What I just did was just customizing a copy of the sample CircleTrackerDemo to include our other functions, since the camera code took up most of the coding. That's probably not the most efficient way, but it works for us.
Let us know what you find, though, since I'd love to shave off a few lines by using the minimal amount of code required.
The difference between theory and application is that in theory, theory and application are the same; In application, they are not.
Unread 12-02-2010, 15:58
Lead Programmer
AKA: Socks
Well, having done some extensive tracing and finally copying the Target.java and the TrackerDashboard.java files to my project, then copying the following code into the Teleop section:
ColorImage image = null;
try {
       if (cam.freshImage()) {
       image = cam.getImage();
       Thread.yield();
       Target[] targets = Target.findCircularTargets(image);
       Thread.yield();
        if (targets.length == 0 || targets[0].m_score < kScoreThreshold) {
             System.out.println("No target found");
             Target[] newTargets = new Target[targets.length + 1];
             newTargets[0] = new Target();
             newTargets[0].m_majorRadius = 0;
             newTargets[0].m_minorRadius = 0;
             newTargets[0].m_score = 0;
             for (int i = 0; i < targets.length; i++) {
                   newTargets[i + 1] = targets[i];
             trackerDashboard.updateVisionDashboard(0.0, gyro.getAngle(), 0.0, 0.0, newTargets);
             } else {
             System.out.println(targets[0]);
             System.out.println("Target Angle: " + targets[0].getHorizontalAngle());
             turnController.setSetpoint(gyroAngle + targets[0].getHorizontalAngle());
             trackerDashboard.updateVisionDashboard(0.0, gyro.getAngle(), 0.0, targets[0].m_xPos / targets[0].m_xMax, targets);
} catch (NIVisionException ex) {
       ex.printStackTrace();
} catch (AxisCameraException ex) {
} finally {
    try {
         if (image != null) {
         image.free();
I've gone through and figured out (mostly) what this code does, but I don't understand what the line
does. In the original file, turnController is:
PIDController turnController = new PIDController(.08, 0.0, 0.5, gyro, new PIDOutput() {
        public void pidWrite(double output) {
            drive.arcadeDrive(0, output);
    }, .005);
but I have no clue what PIDController does. Any help?
EDIT: I know the targeting part probably won't end up in TeleOp, but for now it can stay.
Unread 12-02-2010, 18:55
turnController drives the robot to point it directly at the target using the gyro angle.
The PIDController is designed to slow the robot turn down as it approaches the target gyro angle. Those values (.08, 0.0, 0.5) are coefficients that must match your robot's turning characteristics, so plan to adjust those when you get a real robot to practice with.
The gyro angle was calculated from the camera image by the offset of the target from the center line.
Unread 13-02-2010, 10:47
Lead Programmer
AKA: Socks
Okay, thanks.
Let me make sure I got that straight - I'd be able to use that code in autonomous to point towards the target.
If that's the case, how would I make it tell the next part that it's pointing at the target to shoot (Ignoring getting a ball for now)?
Unread 13-02-2010, 13:50
You'll be pointed at the target when targets[0].getHorizontalAngle() gets small. You'll have to pick your tolerance, e.g., +/- 1 degree, and test for it.
Unread 14-02-2010, 00:34
Lead Programmer
AKA: Socks
Ok, thanks. If I need more help, I'll post it, but I think I've got the gist of this.
2010 Axis Camera Dashboard Problems Kohala2460 General Forum 0 04-02-2010 13:34
2010 Axis Camera Dashboard Problems JesterKarrde Programming 12 04-02-2010 13:11
Java/Netbeans Camera Code for Classmate PC and Axis Camera joshholat Programming 1 23-01-2010 14:59
Dashboard and Robot main with Axis camera Team2883 General Forum 9 10-01-2009 07:35
AXIS Camera nickmagus Programming 1 03-01-2009 20:06
