Go to Post The question is like asking "Is it better to drive by looking at a map the whole time or by remembering where you want to go and watching the road instead?" - lukevanoort [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 12-02-2010, 21:13
John G John G is offline
FRC #0399 (Eagle Robotics)
John G is on a distinguished road
dribbler/roller
What diameter wheels/rollers for turning/dribbling the ball have you guys found that work the best?
Unread 12-02-2010, 21:25
EthanMiller EthanMiller is offline
Lead Programmer
AKA: Socks
FTC #4356 (The Zip Ties)
EthanMiller has a spectacular aura aboutEthanMiller has a spectacular aura aboutEthanMiller has a spectacular aura about
Re: dribbler/roller
1713 is using some PVC we found with wheel tread around it, riveted on. We have that powered by a belt 1:1 with a CIM, no gearing. It works.
When all else fails, read the manual.
FRC 1713 K Island Gears 2009, 2010 (Not 2011 due to budget, hopefully 2012!) - Fingerlakes Regional
FTC 4356 The Zip Ties 2010-2011 Season - NNYRC (2010 9th seed).
Unread 12-02-2010, 21:31
Jones571's Avatar
Jones571 Jones571 is offline
AKA: Corey
FRC #0571 (Paragon)
Jones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud of
Send a message via AIM to Jones571
Re: dribbler/roller
8'' pneumatic tires from skyway. size is more for packaging of the entire system then necessity. Any size should work long as they are positioned correctly.
http://www.youtube.com/watch?v=Mb0_i3hbVNY
Unread 12-02-2010, 21:36
NOV8R's Avatar
NOV8R NOV8R is offline
AKA: Chuck Brant
FRC #1583
NOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud of
Re: dribbler/roller
1583 is using 3 7/8 inch Banebot wheels on 20:1 Banebot 36 mm gearboes with the FP motors. Since the FPs are on Jags we can spin the ball either slow or fast. For example if we back up we speed the dribbler up to make sure the ball stays with the robot. Just before we kick we slow the ball way down to reduce the effects of the back spin on the kick.
Unread 12-02-2010, 21:37
Jones571's Avatar
AKA: Corey
FRC #0571 (Paragon)
Re: dribbler/roller
is that how you solved the issue you were having with the ball hitting the bumpers?
Unread 12-02-2010, 22:02
NOV8R's Avatar
AKA: Chuck Brant
FRC #1583
Re: dribbler/roller
Hi Corey....Yep that's one of the things we've done. We also redesigned the kicking plate.
Unread 12-02-2010, 22:05
Mahekp15 Mahekp15 is offline
FRC #0442 (Redstone Robotics)
Mahekp15 is an unknown quantity at this point
Re: dribbler/roller
well cool! but john there were alot of team mentors asking for indepth roller idea! i will tell you tomorow!
roller chains Peter Randall Inventor 1 30-03-2009 17:21
Roller Grabber Question Po-ser Technical Discussion 9 12-03-2007 00:47
Roller Prototype sdexp Robot Showcase 0 04-02-2006 22:41
Roller Chain Adrian Wong Inventor 3 23-02-2002 17:21
