Go to Post Anyone who makes a minibot that poots out another minibot that blows the wall apart deserves to have it displayed in the Smithsonian. - Koko Ed [more]
Unread 03-02-2010, 01:11
Must Be Drama Must Be Drama is offline
Must Be Drama is an unknown quantity at this point
does any one have a working holonomic mecanum setup?
i tried to stay far away from the holonomic drive, i guess i would have to use it; my possible short cut ways cant work lol
i really dont understand mecanum cause i wasnt on the team of that year we used it
so can some one help drop some incites about setting up;
magnitude rotation and such has me like
thanks in advance
Unread 03-02-2010, 15:07
Re: does any one have a working holonomic mecanum setup?
no help?
Unread 04-02-2010, 01:59
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
There are quite a few other threads that discuss this in detail. Search.
Unread 04-02-2010, 03:32
thanks in advance
Have you asked your teacher/main mentor at all? I know for a fact that he knows what he's doing. Just ask him about your 07 bot.
Unread 12-02-2010, 17:39
Wicked Wicked is offline
FRC #0354 (G-House Pirates)
Wicked is an unknown quantity at this point
From the same team here, our problem's changed a bit.
The basic forward/reverse movement works fine; but when we try to rotate, it instead strafes, and vice versa. We're using the Holonomic.vi that came packaged with the code and the wheel orientation is correct as well. Help would be appreciated, thanks in advance.
Unread 12-02-2010, 21:57
It sounds like you have your PWMs swapped between your left and right wheels on either the front or the back. Make sure the code and the wiring match each other.
Unread 12-02-2010, 22:03
If I understand correctly what you've said, everything is working, so why can't you just switch the strafe and rotate wires "wires" in LabVIEW ?
Unread 12-02-2010, 23:02
bladetech932's Avatar
bladetech932 bladetech932 is offline
Programmer of awesome
AKA: Jon
FRC #0932 (Circuit Chargers)
bladetech932 is on a distinguished road
you can switch the rotate and strafe coming out of the joystick
Unread 13-02-2010, 15:36
robotic321's Avatar
robotic321 robotic321 is offline
FRC #1793
robotic321 is an unknown quantity at this point
I got mine working, but i had to make a home-brewed mecanum drive code.
1793 FTW
Unread 14-02-2010, 04:54
Has anyone tried the updated mecanum VIs from LabVIEW update 2.1?
-Joe
Does anybody have any pictures of team2264 vivek16 General Forum 0 03-11-2007 21:02
does any have a vid of that band N8 # 1141 Championship Event 5 16-04-2007 18:52
Any one have old parts to help a summer program JamesBrown General Forum 3 24-03-2005 20:13
Any one have pics from the J&J regional? archiver 2001 1 24-06-2002 02:44
Any one have info on team 303 archiver 2001 0 24-06-2002 02:17
