Go to Post Us, as adults, find ways to help the kids to make it happen. - aspiece [more]
Unread 13-02-2010, 01:08
daltore's Avatar
daltore daltore is offline
Electronics/programming/design
AKA: Aaron Osmer
FRC #3529 (ausTIN CANs)
daltore has a spectacular aura aboutdaltore has a spectacular aura aboutdaltore has a spectacular aura about
Send a message via AIM to daltore Send a message via MSN to daltore Send a message via Yahoo to daltore
Re: CAN Position control code?
A little background on the 10k potentiometer value in the manual:
The Luminary Micro ARM processor that's in the Jaguar operates off of 3.3v, but the ADC is only 3v tolerant. They have a 1k resistor connected in series to the power pin on the pot input on the Jaguar, so you have to use a 10k pot to cause a voltage drop across the 1k resistor of .3v and the voltage drop across the entire potentiometer of 3v.
By using a 100k pot instead of a 10k, you're causing a voltage drop of 3.27v across the potentiometer. This means that if you pull the pot all the way down to its minimum resistance, the ADC is experiencing 3.27v, which is .27v greater than it was rated for. This might be why you had sporadic results.
If you don't have a 10k pot on hand, don't use a lower value, as that will cause more current to flow, which is also not necessarily good. If you have some spare resistors lying around, try putting them in series or parallel with the two extremes of the potentiometer to achieve 10k. This may reduce your resolution, but it won't break the Jaguar. If you don't have any resistors, wait until the next day.
This is just my take on it, if it works fine for you, go for it, but it may or may not be risky.
Unread 13-02-2010, 02:26
simpsonboy77 simpsonboy77 is offline
AKA: Garrett Dicken
FRC #0041 (RoboWarriors)
simpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond repute
The added voltage ran across my mind, but the potentiometer was mounted in some C channel since it was previously a throttle control for the 2008 robot. So there are physical stops that prevent it from going under .4 and over 2.8.
Also the the original poster, if you post what code you have currently, we could help you debug it better.
2017 Shenzhen, China Regional CSA
2013 - Present MAR Control System Adviser and FTAA
2009 - Present Programming an Electrical Mentor Team 41
2007 - 2008 Team 41 Lead Programmer, Electrical
2005 - 2008 Team 41 Member
2008 NYC Regional Winner
Position Control using potentiometer? biojae CAN 13 03-02-2010 20:12
More CAN control questions Geek 2.0 Electrical 0 12-01-2010 13:40
CAN control weirdness nathanww Electrical 4 04-01-2010 21:13
can we control the amount of air to control the speed of the cylinder? Team2339 Pneumatics 22 11-02-2009 15:33
Where can I find motor control in Camera.c? sjung9442 Programming 3 31-01-2006 15:49
