Go to Post It's better to be safe than sorry. - Dan Petrovic [more]
Unread 13-02-2010, 00:51
toughguy toughguy is offline
FRC #2462
toughguy is an unknown quantity at this point
Unhappy pressure problems
im having problems with getting the pneumatics getting to a pressure of 120 psi. can anyone help?
Unread 13-02-2010, 01:31
Electrical Engineer
Rookie Year: 1995
Re: pressure problems
If your compressor is running and running and you don't get to 120 PSI, here are three most likely causes:
1. Air is leaking from a fitting.
2. Your pressure regulator is installed backward causing air to leak.
3. I know you think you checked but, trust me, air is leaking from a fitting.
pV = nRT
Regards,
Mike
Mike Betts
As easy as 355/113...
Unread 13-02-2010, 09:18
ralfy ralfy is offline
Grumpy Old Rookie Mentor
FRC #3201 (Ross Rambotics)
ralfy is on a distinguished road
Red face Re: pressure problems
We had a chronic problem where we could only get 60 psi. Last night we found an allen head set screw in the (KOP) pressure regulator was leaking. It was not tight. A couple wraps of teflon tape and put it back in snug, and now we can get to full pressure. Hope you have the same simple solution, and it doesn't take two weeks to find it.
Unread 04-03-2010, 09:58
KyleWishnok's Avatar
KyleWishnok KyleWishnok is offline
FRC #2544 (HCRC)
Team Role: Driver
KyleWishnok will become famous soon enough
We had a similar problem with the standard issue plug for the regulator. We got tired of tightening it and decided to teflon a brass plug and use that. Havent had a problem since
Unread 04-03-2010, 10:18
Geek 2.0 Geek 2.0 is offline
FRC #0107
Geek 2.0 will become famous soon enough
Also check the layout of your pneumatic system. We accidentally put the secondary regulator instead of the primary one, causing our pressure to bottom out consistently at a given PSI.
Unread 05-03-2010, 18:15
If your system is getting to 105-110 psi and shutting of, this is normal. The pressure switch is not a precision device. If the compressor never shuts off, then you likely have a leak. On occassion, the vent valve is damaged in manufacture. Try plugging the output of the valve and try again. If you would like, PM me (phone number or email) and I can try to talk you in or come over and help diagnose. Just let me know.
Does the Norgren Pressure Regulator show working pressure or stored pressure? Madison Pneumatics 7 14-02-2008 17:40
Labview problems and code problems ajsetter Programming 25 18-01-2006 17:07
Pressure physics problems sanddrag Math and Science 8 01-07-2005 10:26
Translating pressure sensor readout into actual pressure Mercutio Pneumatics 0 13-02-2004 16:29
Pressure Sensors gthakore General Forum 14 12-01-2003 19:23
