Go to Post I was cheering like mad during the last match on Einstein - I think the rest of my team thought I was crazy...or crazier than they thought I was before! - Sean Schuff [more]
Unread 13-02-2010, 06:34
gbf1991 gbf1991 is offline
FRC #3011
gbf1991 is an unknown quantity at this point
Uploading Code to the cRIO
Hi, its Team 3011 again. We're having an issue similar to whytheheckme and a kenny03, where NetBeans outputs the following text when we attempt to run the program:
[cRIO] GCs: 1 full, 0 partial
[cRIO] ** VM stopped: exit code = 1 **
[cRIO] task 0x2151cb8 (SquawkRobotTask) deleted: errno=0 (0) status=1 (0x1)
Their problems seem to have been solved by updates, but that won't work for us. We have the latest versions of the software, and the code was running fine. Key word "was". One of our programmers had, unbeknownst to me, imaged the 'bot with the code. Not knowing this, I ran the code out of Netbeans as usual, and then stopped it when I looked at the driver's station and saw that there was already robot code. Now the entire thing seems to be FUBAR, but the sample codes do work. I honestly have no idea what to try now, so can anyone help us?
Unread 13-02-2010, 10:04
Khrielo Khrielo is offline
Nick McCormick
FRC #3011 (Robo Warriors)
Khrielo is an unknown quantity at this point
Re: Uploading Code to the cRIO
This is a pretty big issue with only 2 weeks left during the build season, Could anyone help us out with this?
Unread 14-02-2010, 07:09
FRC #3011
Moderators can close this thread. It turns out that our Chief Programmer (who just got back) had left something in the code that we didn't catch. He solved it in ~5 seconds.
Unread 18-02-2010, 16:58
AnibaS's Avatar
AnibaS AnibaS is offline
SuperNerd
AKA: Sabina
FRC #2265 (FeMaidens)
AnibaS is a splendid one to beholdAnibaS is a splendid one to beholdAnibaS is a splendid one to beholdAnibaS is a splendid one to beholdAnibaS is a splendid one to beholdAnibaS is a splendid one to beholdAnibaS is a splendid one to behold
Send a message via AIM to AnibaS
Our team is also having the same problem. Can you tell us what you guys changed to make it work?
Join us on Facebook!
uploading source onto cRIO?! NetSkay Programming 5 13-01-2012 19:41
Code suddenly stopped uploading? sp33chy Java 2 08-02-2010 18:53
Problem uploading code from a VM LinuxMercedes C/C++ 5 12-01-2009 23:31
"Battery: No Code" after uploading .out file to cRIO knine143 FRC Control System 1 20-12-2008 22:14
Uploading Old Code G1279 Programming 1 12-01-2008 22:35
