Go to Post I realize that I've been drawn into the trap of thinking that this is about robots and scores and winning. Reboot. Remember why we do what we do. - Mr. Van [more]
Unread 13-02-2010, 01:01
Creator Mat Creator Mat is offline
FRC #2338 (Gear it Forward)
Creator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the rough
Checking <R19>
How will the inspectors be checking for rule <R19> (the rule that says that the ball can't go more than 3" into your frame) compliance this year? Last year to check if the trailer hitch was mounted correctly the inspectors had a plastic cut out that they used, would there be something similar to that this year? If so could someone post a picture or some drawings of it?
Thanks
2010 Midwest Spirit award
2010 Midwest Quarterfinalists
2010 Wisconsin Quarterfinalists
2009 Midwest Finalists
2009 Wisconsin Quarterfinalists
2008 Midwest Rookie AllStars
Unread 13-02-2010, 01:22
Electrical Engineer
Rookie Year: 1995
Re: Checking <R19>
Thanks
Mat,
We have not seen the inspection checklist for this year yet so we don't know...
When it is published, I would expect to see the grayed out link placeholder on this page to turn blue.
Since there is no rule against a ball going under your robot as long as it does not hit a mechanism, this issue may not be an inspection issue. Rather, it may be a field call by the referee...
As soon as we know what FIRST expects, I'm sure that you will see something on these forums...
Regards,
Mike
Mike Betts
As easy as 355/113...
Unread 13-02-2010, 02:37
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Re: Checking <R19>
That is not correct. Please read Rule <R19> carefully.
Unread 13-02-2010, 07:05
Electrical Engineer
Rookie Year: 1995
Re: Checking <R19>
I stand corrected.
However, I still do not know what the inspection checklist will say. And more to the point of the original post, I do not know what devices or fixtures we may be using to inspect this.
Regards,
Mike
Mike Betts
Unread 13-02-2010, 09:08
Re: Checking <R19>
ok thanks. Any idea of when they might release the check list?
Unread 13-02-2010, 09:13
Electrical Engineer
Rookie Year: 1995
Re: Checking <R19>
I was hoping for it a while ago...
Mike Betts
Unread 13-02-2010, 11:23
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Checking <R19>
A thought for a checking device: Use a ball with a circle drawn around it like the picture here: http://planetmath.org/encyclopedia/I...eAndPlane.html
The distance between the plane intersecting the ball that defines the circle, and the plane that is parallel to that plane and is tangent to the ball is 3".
Now stuff the ball into any opening in the robot to see if the circle is swallowed by the robot. If so, there is a violation of <R19>.
Note that <R19> says the robot must be designed so that there can be no incursion greater than 3". Should such an incursion occur, you will get a PENALTY under <G46>. But <R19> says there should be no opportunity to get such a PENALTY, because the robot should have been designed so it can't happen.
(since 2004)
Unread 13-02-2010, 16:13
Electrical Engineer
Rookie Year: 1995
Re: Checking <R19>
Gary,
It is a bit late for this type of brainstorming.
Any such device, if it is going to be used, very likely already exists.
FIRST needs to provide all regionals with equal tooling and guidelines or the teams suffer from regionals with unequal inspection standards.
Regards,
Mike
Mike Betts
R19 MarcusF Rules/Strategy 12 09-01-2010 21:49
pic: Checking it Dylan Gramlich Extra Discussion 5 27-03-2007 15:03
Checking for leaks?? Nathan B. Pneumatics 5 13-02-2005 10:06
Good idea? Joystick packet checking? MADCOW Programming 1 30-01-2004 21:00
need help double checking... Ken Leung Technical Discussion 4 26-11-2001 16:28
