Go to Post FIRST loves robot heroes. - Rick TYler [more]
Unread 12-02-2010, 20:04
hannigan hannigan is offline
FRC #2264
hannigan is an unknown quantity at this point
How to connect the 12v solenoid to the cRIO and spike relay?
I am trying to set up the pneumatics but I don't know how or where to connect the solenoid. Do I need to connect it to the digital or analog on the cRIO. Do I need to use the spike relay and if so how do I do it. I would like pictures because it's hard to picture without it.
Unread 12-02-2010, 20:05
EricH EricH is online now
Re: How to connect the 12v solenoid to the cRIO and spike relay?
You can connect it directly to the solenoid breakout or to the relay area via a Spike. Your choice.
Unread 12-02-2010, 20:28
EricWilliams EricWilliams is offline
FRC #2039 (Rockford Robotics)
EricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of light
If you are connecting it to the Solenoid Module of the cRIO, you can cut the grey two pin cables that came in the KOP in half, and use the heads from those. Solder the wires of the solenoids to those connectors, and you should be all set to plug it to the cRIO module.
Good luck!
Unread 13-02-2010, 09:21
The Solenoid Module in turn gets a power connection (little white Wago connector) directly to the Power Distribution Panel (red/black Wago connectors & a 20 amp snap-action breaker).
multiple cRIO relay (solenoid) modules? Alan Anderson FRC Control System 15 06-02-2010 17:41
How to connect the Workbench with the cRIO? kentschool C/C++ 3 28-12-2009 16:03
How do you run the pneumatics through the CRio w/o using the Jaguars and the Spikes brreadd Pneumatics 3 20-11-2009 15:35
Pneumatics (Spike Relay, Solenoid etc.) Programming oceansidehs Programming 8 10-02-2007 13:58
