Go to Post CD is not the GDC. (Otherwise we'd be better at getting the game hints! ;) ) - Ninja_Bait [more]
Unread 12-02-2010, 21:21
Anon Anon is offline
Anon is an unknown quantity at this point
Spike Relay Double Solenoid
We are using LabView 8.6 and we are trying to program an SMC double Solenoid connected to a Spike relay. We have programmed a single relay but it does not work for our double solenoid. Only our single solenoid. We've connected both red wires of the double solenoid to the M+ and the M- of the Spike relay. How can we adjust our code so it works with a double solenoid?
-Thank you in advance
Unread 13-02-2010, 06:58
charrisTTI charrisTTI is offline
Ramblin' Wreck
AKA: Charles Harris
FRC #0623
charrisTTI has a spectacular aura aboutcharrisTTI has a spectacular aura about
Send a message via AIM to charrisTTI
Re: Spike Relay Double Solenoid
Here is the link to the IFI documentation for the spike. See the two solenoid wiring example to check your wiring.
http://content.vexrobotics.com/docs/...uide-sep05.pdf
Set relay forward momentarily to switch to one position.
Set relay reverse momentarily to switch to other position.
Valve will maintain position without power.
Other points:
Dual solenoid valves must have air pressure applied to move the spool in the valve
This years KOP the dual solenoid valve is 24V, check documentation about this. Spike is designed for 12v so you will have to us the NI solenoid driver card with special 24v wiring to use this years valve.
FRC 623 2003,2004,2005,2006,2007,2008, 2009, 2010, 2011
FRC 1900 2007
FVC 60 and 193 2006
FVC 3271 2007
FTC 226 and 369 2008, 2009, 2010, 2011
FTC 3806 2010
Unread 13-02-2010, 09:34
What does the True case for the Relay Set have in it (should be "Forward")?
How to connect the 12v solenoid to the cRIO and spike relay? hannigan Pneumatics 3 13-02-2010 09:21
Relay (Spike) elbuo Electrical 2 09-02-2009 20:36
Spike relay question Zack Briggs Electrical 17 19-02-2008 14:48
Pneumatics (Spike Relay, Solenoid etc.) Programming oceansidehs Programming 8 10-02-2007 13:58
Spike Relay Input nwagers Electrical 3 16-07-2002 22:23
