Re: Software update?
Where did you find the v20 update? We still only have v19.
Thanks! |
It would also be nice to know what was updated. For example, we submitted a concern on the FIRST forums about the DS not reading the d-pad on a gamepad correctly. We have since worked around this by adjusting our control scheme, but it would be nice to know if/when it's fixed so that we can go about our original plans.
Has anyone found release notes? I haven't installed it yet, but I don't remember any release notes on the last update. Maybe I'll come across it this time. |
we updated to v20 today and now netbeans is complaining that we're on v20 (it's looking for v19) any thoughts?
thanks |
We are in the same situation...did the mandatory labview update, updated the CrIO, which is now at v20. NetBeans now gives us the message, "Expected version FRC_2010_v19.zip;"
This is probably why it wasn't announced yet. I'd reccomend going into Tools > Plugins, and checking for updates there.
#7
After applying the patch 4.2 to fix the problems created by C++ update 4.1, We get the "reference to undefined symbol" errors for _ZN10AxisCamera11GetInstanceEv ... etc. |
#8
In this file, if you change FRC_2010_v19.zip to FRC_2010_v20.zip then the code will download and execute on the cRIO with the V20 image. Note: There may need to be other changes to the Java Netbeans plugins for complete support of V20. This solution appears to work for our code so far. |
#10
I can confirm editing the sunspotfrcsdk/ant/upgrade.xml file seems work for us as well.
#11
We updated successfully (we're using LabVIEW). BIG improvement. We were having a lot of communication problems when using wireless. No issues anymore.
#12
We have the exact same problem, anyone have any thoughts?
#13
I saw this this morning, and downloaded and installed the update.
Don't make the same mistake. Netbeans refuses to download code (as others have said, because it's looking for image v19). After scrounging the v19 image off of another machine, I tried reimaging with the updated software. I must've tried 5 or 6 times with no luck on two machines. Reimaging with a non-updated machine worked like any other re-imaging. Downdating with the v2.0 LabVIEW update won't work because there's a newer software version installed. You'll either have to uninstall and reinstall the software or find another computer to reimage it. After the successful reimaging, I'm now having an issue where I get: Code:
Connecting FTP @10.15.33.2 upgrade: Sending local file image.suite flashapp: deploy: init: Waiting to connect to OTA command server of 10.15.33.2:8001 for past 11s EDIT: Nevermind, I just had to let the cRIO sit, off, for a little. Code now downloads. Last edited by KevinJ : 13-02-2010 at 14:24. Reason: Fixed it |
| Camera software Update 2/3/10 C/C++ | jault | Programming | 13 | 11-02-2010 15:30 |
| software update problem | qpang | General Forum | 1 | 22-01-2010 19:08 |
| password for software update? | qpang | General Forum | 1 | 21-01-2010 16:10 |
| Problems with required software update | eugenebrooks | Programming | 0 | 14-02-2009 00:50 |
| **FIRST EMAIL**/Control System Software Update Reminder | Mark McLeod | FIRST E-Mail Blast Archive | 13 | 30-11-2008 21:05 |
