Thread Tools |
Rating:
Display Modes |
#12
Re: can't Download code to cRIO
Try to take one of the example projects and download it. Sometimes there will be a bug in the code that may prevent it from downloading/running correctly. If you can't deploy a default project, then you know for sure that it's not a problem with the code and that it is a problem with something in the downloading process.
Also, make sure you have the latest updates for everything you're using. Apparently there was an update recently (I think for the DS) that you had to install twice, because it didn't work the first time. Make sure everything is installed and updated. Good luck! |
| Need to manually reboot cRIO to download code | FRC4ME | Java | 6 | 24-01-2010 15:59 |
| Another Can't Download Code Thread | rjn | C/C++ | 9 | 24-01-2010 10:17 |
| Cannot get Code to Download to cRIO | greekgod8591 | C/C++ | 25 | 09-03-2009 22:10 |
| Can't Download Code | nickmagus | Programming | 1 | 05-01-2009 17:52 |
| Can't download from Autodesk FIRSTbase | Bomberofdoom | Inventor | 11 | 01-01-2008 20:06 |
