Go to Post I love robotics, it has a spot for every kinda future career a student chooses. - Bharat Nain [more]
Unread 13-02-2010, 09:57
Team Alchemy Team Alchemy is offline
FRC #3141 (Team Alchemy)
Team Alchemy is an unknown quantity at this point
Exclamation Problems
My team (Team Alchemy - 3141) is having troubles getting the PWM signals to move the motors. Pretty much, the motors won't move. What is the solution for this problem or what even is the problems source?
Thank You
William Surgeon
<Team Alchemy >
Unread 13-02-2010, 10:03
bladetech932's Avatar
bladetech932 bladetech932 is offline
Programmer of awesome
AKA: Jon
FRC #0932 (Circuit Chargers)
bladetech932 is on a distinguished road
Re: Problems
cheack the pwm cable,the sidecar the signals coming from,the program making the motor move,and the jag/victor that runs the motor
use a multimeter to check the pwm and the jag/victor
Unread 13-02-2010, 10:46
Exclamation Re: Problems
We have already done that and it still doesn't work.
<Team Alchemy >
Unread 13-02-2010, 11:13
Question Possible Jaguar error?
Could it be an error with the jaguars?
Also, what are the error codes.
<Team Alchemy >
Unread 13-02-2010, 11:14
EthanMiller EthanMiller is offline
Lead Programmer
AKA: Socks
FTC #4356 (The Zip Ties)
EthanMiller has a spectacular aura aboutEthanMiller has a spectacular aura aboutEthanMiller has a spectacular aura about
Re: Possible Jaguar error?
What are the lights on the Jags doing?
When all else fails, read the manual.
FRC 1713 K Island Gears 2009, 2010 (Not 2011 due to budget, hopefully 2012!) - Fingerlakes Regional
FTC 4356 The Zip Ties 2010-2011 Season - NNYRC (2010 9th seed).
Unread 13-02-2010, 11:20
Re: Problems
Constant yellow blink even when we only have power to it.
<Team Alchemy >
Unread 13-02-2010, 11:25
Re: Problems
One is now constant yellow and the other is still blinking yellow.
<Team Alchemy >
Unread 13-02-2010, 11:27
Both are now constantly on.
<Team Alchemy >
Unread 13-02-2010, 11:31
Teammax's Avatar
Teammax Teammax is offline
30 Members 6 Weeks 1 Dream
AKA: Rob Cormier
FRC #1071 (Team MAX)
Teammax is just really niceTeammax is just really niceTeammax is just really niceTeammax is just really nice
Re: Problems
You guys are pretty close to us (Wolcott). If you want we can meet some time and see if our programmers can figure out what is going on. I will send you a message with my email and cell phone number. We are around all week to help out if needed.
Unread 13-02-2010, 11:36
Lead Programmer
AKA: Socks
Re: Problems
Blinking yellow means no signal. What programming language are you using?
And double check the PWM cables - both the sidecar and the Jaguars have labeling for how they should go.
Unread 13-02-2010, 13:17
EOC's Avatar
EOC EOC is offline
AKA: Eric Curry
None #1208 (Metool Brigade)
EOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant future
Re: Problems
A common error (we have done it more than once) is to plug the pwm cable in backward.
Unread 13-02-2010, 23:58
sniggel sniggel is offline
FRC #2051
sniggel is an unknown quantity at this point
Re: Problems
check that your code is using the correct pwm for the motor you are wiring to. also check that your wire is connected correctly, if you flip the wires and the connectors are reversed the jaquars will flash yellow.
Problems AlexD744 General Forum 2 27-08-2009 16:42
DS Problems popo308 FRC Control System 3 05-01-2009 22:16
Labview problems and code problems ajsetter Programming 25 18-01-2006 17:07
Problems muy dificil Programming 5 26-10-2005 17:10
Problems, problems . . . archiver 2000 6 23-06-2002 23:00
