Go to Post Sometimes it is worth it to stop and read what you've written before posting. - [more]
Unread 09-02-2010, 22:01
Thundr Whale Thundr Whale is offline
FRC #3299
Thundr Whale is an unknown quantity at this point
Camera Config Fail.
Hooookay so team 3299 now officialy joins the ranks of those who are having camera fail.
I read
http://www.chiefdelphi.com/forums/sh...amera+problems
that forum front to back, but the thing is, we aren't even getting as far as these people, we can't get the camera configure and changing the user name and password to FRC, FRC.
We are following the directions in the Control System Manual, going to
http://192.168.0.90/
and then it asks for login and password, i enter "root" and "pass" like it says, and nothing happens.
So how do we configure the camera so that it can talk to labview and the cRIO?
Unread 10-02-2010, 10:08
Mike Mahar Mike Mahar is offline
FRC #0138
Mike Mahar will become famous soon enough
Re: Camera Config Fail.
Your best bet at this point is to start over. On the back of the camera is a small black button. This is the reset button. Press and hold this button down while you unplug the power for the camera. While holding the reset button, plug in the power. Keep holding the reset button for several seconds and then release.
Now, with the camera connected to your PC, navigate to the camera with our browser to 192.168.0.90. The camera should respond with a window asking you to set the root password. Set this password to "admin". The camera will then ask you to log in. Use the user name "root" and password "admin". This should get you to the main camera pages. From there, you can navigate to the page that lets you set up additional users. Add the FRC user with password FRC and you should be good to go.
Unread 10-02-2010, 11:08
Originally Posted by Thundr Whale View Post
...i enter "root" and "pass" like it says, and nothing happens.
What browser are you using? We discovered that Safari didn't work with the WGA600N login screen. Perhaps there's something similar tripping you up with the camera.
Unread 10-02-2010, 17:36
I'm away from the FRC documentation, but I don't recall any password being on the camera when shipped from the factory. The first time you log in, it asks for a password for the root account. With this you can add additional user or admin accounts. Of course if you have access to the camera, you can press the button and redefine everything as listed in the previous posting.
Greg McKaskle
Unread 13-02-2010, 13:32
ninjasquid ninjasquid is offline
FRC #3299 (The Warehouse Crew)
ninjasquid is an unknown quantity at this point
Thank you all for your help, our camera is up and running with live feed!
Camera custom config pafwl C/C++ 2 31-01-2010 01:33
Solenoid is teh fail Nick Seidl Pneumatics 23 25-01-2010 13:07
Victor=Fail on second digital sidecar Robostang 548 NI LabVIEW 0 14-02-2009 18:33
Camera Config doesn't save! comwiz7 Programming 2 20-02-2006 17:19
I fail to see the point.. randomperson Programming 14 27-03-2003 11:38
